bracket question for RTi28
Does anyone have bracket recommendations for the RTI28. I need them to articulate downward about 40-45 degrees from the horizontal. Thinking about omnimount 20.0 but not sure yet.
Yamaha HTR 5590
RTi 70
CSi40
RTi 28
PSW 303
Yamaha HTR 5590
RTi 70
CSi40
RTi 28
PSW 303
Post edited by jason_fay on
I'm using B-Tech brackets for my RTi35's due to their weight. Here's a link, and they arent cabinet damaging either.
<55 lbs.
http://www.crutchfield.com/cgi-bin/S-lOgQnIJfnZY/ProdView.asp?s=0&c=9&g=15830&I=121BT77B&o=p&a=0&cc=01
They have a bunch on Crutchfield.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
thanks for the help, i think i will go with them through the polk website
If these are for your rear speakers, you don't want them pointing down. They are effect speackers, about 6' off the ground is fine.
http://www.polkaudio.com/home/library/hthandbook.php
Download the guide and read through it.
hope this helps- GregAVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One -
i wish i could put them 6 feet off the ground, but i'am 6'5" and one of them will end up hitting my shoulder when I walk past it. need to have them at least 7 feet
that would be fine, they are non-directional effect speakers in HT.AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
thanks for the input and link. I mounted them yesterday without the brackets and it sounds great.:D
