Need a CD Bootable CD
disneyjoe7
disneyjoe7 Posts: 11,435
edited June 2009 in The Clubhouse
Help.
Lost.
Confused.
And
Frustrated.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • Systems
    Systems Posts: 14,873
    edited June 2009
    You need a CD you can boot to? Might need to explain a little further. Drop in your Windows CD/DVD and boot to that? I'm confused.
    Testing
    Testing
    Testing
  • renowilliams
    renowilliams Posts: 920
    edited June 2009
    disneyjoe7 wrote: »
    Help.
    Lost.
    Confused.
    And
    Frustrated.
    You need to be more specific about what kind of bootable cd you need. Firstly, what type of computer do you have (custom built or an H.P,Dell,Acer etc...) Are you looking for an operating system disk ie XP or Vista. Or are you looking for a bootable disk which will allow you to use dos commands?
    Tim
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • disneyjoe7
    edited June 2009
    Ok thanks for the reply....
    My wifes computer a Dell Laptop with Vista Home 32bit. She's over it and what's it OFF, I can install Win XP on it or Win 7 for now. But since it's a laptop need a clean install either way XP or 7, so to due so I need a boot cd so I can wipe hard drive.
    I have a nice Win98 boot floppy but can't seem to find a way to make a CD bootable.
    Or is it easier with a USB, but since I have her backup files on it... I'm don't wish to mess that up.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • obieone
    obieone Posts: 5,077
    edited June 2009
    Is this what you're looking for???
    http://www.dban.org/
  • nadams
    nadams Posts: 5,877
    edited June 2009
    If you have either the XP or Win7 CD, they'll be able to wipe the drive, no additional disks needed.
    Ludicrous gibs!
  • disneyjoe7
    edited June 2009
    obieone wrote: »
    I'm doing something wrong here, I downloaded this file below. Then burned and rebooted no go not bootable.
    http://sourceforge.net/project/downloading.php?groupname=dban&filename=dban-1.0.7_i386.iso&use_mirror=hivelocity
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited June 2009
    nadams wrote: »
    Really I always fdisk'd a drive first, but maybe I'm adding a step or two? Would that clean a partition also, making it one large drive?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Systems
    edited June 2009
    Drop in the XP CD and choose to boot to the CD drive in the bios. When the computer starts select to boot from CD then delete all patitions. Create a full partition using the maximun space on the hard drive (or create a small partition and copy XP to that partition and use it to load XP from a DOS prompt) and then format and install XP. Go to another computer and make a driver disk from the dell download site for all the drivers you need for the laptop that XP doesn't install.
    Done.
    Testing
    Testing
    Testing
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited June 2009
    disneyjoe7 wrote: »
    If that's what you want it to do. When it gets to the setup screen, you will have three options. Install on selected partition. Delete selected partition, create partition. Just delete them all and create one large partition.
  • disneyjoe7
    edited June 2009
    Thanks all, I'm going in... It's all or nothing now.
    Would like a bootable CD with some tools (DOS tools?) for the future. But for now it will work.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • WilliamM2
    edited June 2009
    disneyjoe7 wrote: »
    Here you go:
    http://www.ultimatebootcd.com/download.html
  • disneyjoe7
    edited June 2009
    WilliamM2 wrote: »
    Ok tried it on my laptop, downloaded burn it... Didn't work. Then found some other software on download.com http://download.cnet.com/UBCD4Win/3000-2086_4-10550208.html which build from your OE software? Well it failed as it failed to build cleanly having 72 errors. So I'll try this on another computer tomorrow, as I give up tonight. But now I question if I even if I need this as I have Linux boot CD which allow me to get files off a BSOD machine. Then if I can use a OS disk to redo / format a disk, do I need anything else?
    On a side note, the Win 7 64bit looks and runs really sweet so far on my wifes laptop. Got a little weird when my wife needed Adobe Flash software, but the Vista option worked ok.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • WilliamM2
    edited June 2009
    It's an iso file, you don't burn it directly to the disc. How are you burning it? If you don't have software that will burn an iso, go here, it's free:
    http://cdburnerxp.se/
  • megasat16
    megasat16 Posts: 3,521
    edited June 2009
    I'll give it a shot! Your Bootable Drive Order might be set to boot from hard drive first?
    Did you check your BIOS to boot from CD first?
    Try the Knoppix Live CD from here. It's pretty sure a bootable image.
    http://www.knoppix.net/
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • WilliamM2
    edited June 2009
    Good thought, but he was able to boot to the Win7 CD and install it.
  • renowilliams
    edited June 2009
    disneyjoe7 wrote: »
    There is a boot cd called Hiren's boot cd that not only allows you to boot to a dos prompt but also will allow you to get files off a computer with a corrupted operating system. This cd also has a lot of utilities for checking hardware. I highly recommend it.
    Here is a link
    http://soft.softoogle.com/ap/hiren-s-bootcd-download-6916.shtml
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • disneyjoe7
    edited June 2009
    I'm testing my "Boot CD" by changing BIOS so it just boots from CD. If it boots it does, if not it gives some "Non bootable software" message.
    I don't seem to have an issue with burning a CD, but finding a good software link. Can anyone post a link for what you guys are talking about? If not happy with Salk Linux boot CD for file recovery, but one the other hand a DOS based would be nice also.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sami
    Sami Posts: 4,634
    edited June 2009
    disneyjoe7 wrote: »
    If you only need to get the files off, then that's all you need.
  • disneyjoe7
    edited June 2009
    Here is a link
    Ok I'm lost or I getting tried of burning CD to find it doesn't work.
    Downloaded this file above unzip'd it and burned only the ISO file to disk. Rebooted and have this message again.
    "No bootable devices--strike F1 to retry boot, F2 for setup utility." If CD is bootable then it works fine I never see this message.
    What I'm doing wrong, and I need it in little steps. :o
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • megasat16
    edited June 2009
    Your CD/DVD lens may need cleaning? When you put a bootable CD, did you see any lights from the CD at bootup indicating that the computer is reading the CD and before it comes up with unbootable devices error?
    Do you have any other computer to try and see that the bootable CD you created is good?
    It's probably that the CD reader in your computer can't read CD-R media if it's too old.
  • Sami
    Sami Posts: 4,634
    edited June 2009
    Are you burning the <file>.ISO to disc or are you creating the disc from the ISO? Big difference. Download ImgBurner and use it to burn a disc from the ISO.
    http://www.imgburn.com/
  • WilliamM2
    edited June 2009
    disneyjoe7 wrote: »
    WilliamM2 wrote: »
    Again.
  • disneyjoe7
    edited June 2009
    Thanks William,
    I'm working on dailup right now, I download this later to see if it does make a difference. But since I downloaded Nero as a trial, does this software offer a bootable option? I'm missing something? I just right clicking file and send to burner drive then burn from there. It works for Win7 software, but nothing I burned to boot?
    For the record, I tried this CD on another computer it didn't boot either.
    Sami, I don't know what you're saying... But what I'm doing from the statement above?
    Thanks all.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sami
    Sami Posts: 4,634
    edited June 2009
    disneyjoe7 wrote: »
    From Nero, select "Burn Image" option. Do not burn the ISO on the disc as a file, it is an image of the disc.
  • disneyjoe7
    edited June 2009
    Sami,
    Dead on buddy, worked as a charm.
    Thank YOU.
    Now I feel like a dummy.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • megasat16
    edited June 2009
    With nero installed, I can just double click on the ISO file and it'll burn the ISO file as an image file. I think you went a great length to burn the ISO file (copy) by opening Nero and choose to create a data CD? :)
  • renowilliams
    edited June 2009
    Glad to see you got it burned. Sorry, I should have explained more clearly how to deal with an image file. I usually just right click on the file and select to open with the burning program I want to use ie: Roxio , power iso etc... or as megasat says double click on the file and the default burning program will open up pre-selected to burn an image.
    Anyway, I'm sure you'll like the Hirens boot cd.
    Tim
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • disneyjoe7
    edited June 2009
    Yes, Hirens CD is cool and has many tools on it nice. Ultimate BootCD nice also, but Hirens wins due to password fixes. Darik's Boot and Nuke title fits this CD pretty well, use CAUTION if booting from this one or really know what you're doing ;)
    Nice to have some options for that BSOD which you can't recover from one day, hate to lose all those pictures I like to take again.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sami
    Sami Posts: 4,634
    edited June 2009
    Now that you're doing the filesystem again, put all that important data on a separate partition. That way it's still there even if you need to do a clean install again.
