Fx lsi
bdtae5656
bdtae5656 Posts: 235
edited June 2009 in Speakers
Ok...I just purchased a pair of Fx's and wanted to know where is the best place to hang-Side or rear? Any other suggestions would be great.
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Post edited by bdtae5656 on
  • Mark1
    Mark1 Posts: 41
    edited June 2009
    You could try listening them in both positions. On the sides in dipole mode they get a wrap around effect you might enjoy better.
  • megasat16
    megasat16 Posts: 3,521
    edited June 2009
    Are you making your system 5.1 or 7.1 system? If you don't have rear surround yet, please these on the rear of your system to have full 5.1 (front left, front right, center, rear left, rear right, subwoofer) system.
    If you already have rear surround speakers (5.1) already, place them on the side or hang them on a wall about head / ear level from the wall. It'll give you a 7.1 surround system.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • blueboxer
    blueboxer Posts: 621
    edited June 2009
    If you go 7.1 do you put the dipoles on the sides and monitors in the rear or vice versa?
  • megasat16
    edited June 2009
    blueboxer wrote: »
    You can use LSiF/x for dipoles or bipoles radiation and can either placed on the rear or the sides. You can use two pairs of LSiF/X (one for rear and one pair for sides) and there is a switch on each speaker to change as dipole or bi-pole so play with the setting to see what sounds better in your room (based on where you placed them).
    If you have a pair of monitor or some other normal speakers, I believe it'll yield better result if you use them as rear surround and use LSiF/X as side surrounds.
    As always, play with position / placement in your room for all speakers for optimal sound quality. Of coz, some don't have a choice when it comes to placement and speaker settings (auto or manual) should be adjusted for better results.
  • bdtae5656
    edited June 2009
    megasat16 wrote: »
    Its going to be 5.1 and stay that way, theres not many Blueray movies that are 7.1 yet.
    Please explain the Bi and Di for me....
    Thanks,
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • megasat16
    edited June 2009
    If you have the LSiF/X manual, it can explain better than I can. If you don't have one with your speakers, you can find it from the link below.
    It'll be helpful to read it thoroughly how to properly setup the surround speakers and how to position, etc.
    http://www.polkaudio.com/downloads/manuals/home/LSiC_FXManual.pdf
    Text Below is taken directly from the manual!
    Direct surround effects—bi-pole mode [figure 3a & 3b]: If you plan on placing
    the speakers more than one foot (30cm) behind the primary listening position we
    recommend using the “bipole” switch setting [figure 2] and placement.
    Diffuse surround effects—di-pole mode [figure 4]: For a more diffuse effect,
    place the speakers on the side walls in line with your listening position and at
    least 2 feet away from the rear wall. Select the “dipole” switch setting[figure 2].
    In either case place surround speakers at least 2 feet (60cm) above seated ear height.
  • bdtae5656
    edited June 2009
    What should the cossover by on these speakers? 60, 80, 100, large, etc
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • Emlyn
    Emlyn Posts: 4,536
    edited June 2009
    bdtae5656 wrote: »
    80 is usually the standard recommendation for surrounds, although you can easily vary it to see if you notice anything better with a lower or higher setting. Occasionally over the years I've gone to 60 on front speakers, but have just stuck with 80 for the center and surrounds.
  • jimmydep
    jimmydep Posts: 1,305
    edited June 2009
    bdtae5656 wrote: »
    I've tried different xo settings with the LSIFX's but I like the speaker set to small with the xo at 60hz the best....I have the speakers on stands about 4ft to the side and 1.5ft to the rear of my listening position with the switch set to Bipole.
    I did have them wall mounted behind me about 6ft off the floor but the WAF was low and actually they sound MUCH better at ear level.
    jimmy
  • bdtae5656
    edited June 2009
    Ok....These things sound amazing! At first I had them 2 feet above my ear level(5 feet from the ground and 2 feet from the back wall) like the manual suggested, but it sounds better when you drop them drop to ear level.
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • jimmydep
    edited June 2009
    bdtae5656 wrote: »
    I found the LSIFX's at about ear level sound the best also, I'm not sure why they recommend the speakers be placed 2ft above ear level.....???
    I'm glad you like them, they are excellent sounding speakers.
    Jimmy
  • Bernal
    Bernal Posts: 991
    edited June 2009
    bdtae5656 wrote: »
    I am 100 per cent:LSi/fx
    I got 2 feet above my ear level (5 feet from the ground and 2 feet from the back wall) as the manual says.
    I like the speaker "fx" set to small with the crossover at 60Hz.
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's
    03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    04) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport (change for a OPPO BDP-83 Blu-ray Disc Player will be available soon)
    05) HITACHI P55T501. 55" HD1080 Plasma HDTV
    06) POLKAUDIO LSiC (Center speaker)
    07) POLKAUDIO LSi15 LEFT (Front speaker)
    08) POLKAUDIO LSi15 RIGHT (Front speaker)
    09) POLKAUDIO LSif/x LEFT (Surround speaker)
    10) POLKAUDIO LSif/x RIGHT (Surround speaker)
    11) VELODYNE OPTIMUN SERIES (High Output Digital EQ SubWoofer 2400W/1200WRMS)
  • bdtae5656
    edited June 2009
    Ear level is diff better! Im wondering why Polk recommends two feet from the wall? On my set up, two feet from the wall is past my ears and all I get to hear is the twitter; while the mid is sending out to the TV
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
