Connecting speakers to two seperate channels
MrGlobe
MrGlobe Posts: 401
edited June 2009 in Speakers
Hello,
I have been unable to find the answer to this question. I understand bi-wiring, and to some extent bi-amping, but I am wondering if it is a bad idea to connect a speaker to both the A and B outputs. To be clear, I mean connecting Monitor 40s to a Sony STR-D965 reciever so that one set of terminals on each speaker is connected to (A) Front speaker and one set of terminals is connected to (B) Front speaker. This would provide each speaker with 100w for the mids and 50w for the tweets.
Not sure if you guys get what Im saying, but thanks in advance for the help!
Globe
Post edited by MrGlobe on
  • VSchneider
    VSchneider Posts: 443
    edited June 2009
    Unless that's something suggested in the manual, generally you shouldn't.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    Connecting it like this will change the impedance of the speaker, and isn't recommended.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
