Best external HD cleaner software?
apc
apc Posts: 779
edited June 2009 in The Clubhouse
I need to really clean some HDs - like govt clean. Any suggested software?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • Jstas
    Jstas Posts: 14,842
    edited June 2009
    If you need government level of clean, the government has utilities available to achieve that. But then again, the government considers "cleaning" to be a through degaussing.
    If you need software, Google is your friend.
    Expert Moron Extraordinaire
  • edbert
    edbert Posts: 1,041
    edited June 2009
    http://www.heidi.ie/node/6
    I have used this before. Seems to work well. I have another one installed on my computer at home but I forget what it was. I think the hard drive cleaner portion was part of another program. I'll let you know when I get home this evening.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • BigMac
    BigMac Posts: 849
    edited June 2009
    This one is free and works very well. I had a friend try to recover data that I deleted with this using hardware recovery which is much more in depth than software recovery. Needless to say he did not recover anything. I still use it today. You have the option to overwrite files,delete whole drives,do a secure move and so on. You can choose the level of removal as well; starting at 1x overwrite to the 35x Gutmann method. If you go this route d/l the Eraser 5.8.6a version, not the beta version as it has not been tested to see if 'everything' is erased.
  • polktiger
    polktiger Posts: 556
    edited June 2009
    wild thought, can you use an electromagnet like you used to use on casette tapes and floppy disks
  • ninerbj
    ninerbj Posts: 870
    edited June 2009
    Am I missing something? Why would you want to do this?
    "she had the body of Venus, with arms."
  • edbert
    edbert Posts: 1,041
    edited June 2009
    It deletes any traces of your old information (and possibly sensitive info like bank accounts, ssn, etc.) if you are planning on sellling a hard drive or old computer with the hard drive. Other than that, I don't know of any real reason.
    Pioneer VSX-816
    CS1 - center
    XBOX
    SOPA since 2008
    Here's my stuff.
