Grace 707 Tonearm parts, information
inspiredsports
inspiredsports Posts: 5,502
edited August 2014 in Electronics
I recently purchased a turntable with a wonderful Grace 707 tonearm. It is missing a small (perhaps 4 or 5 gram) anti-skate (bias) weight. It works well without, but I think the right channel would sound even more dynamic with it.
Does anyone happen to know the exact weight of this missing piece so tht I might fabricate one, or better yet, have an original I might purchase?
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
    SCompRacer Posts: 9,090
    edited June 2009
    Not sure of the exact weight you would need. Maybe ask at Audiogon, Audiokarma, etc. if you can't find the weight of the original missing piece. You could use small scale calibration weights or fishing line sinkers. They are available in various weights, like 100 grams on up.
    edited June 2009
    My bad, I meant to say I've seen calibration weights from 1 gram on up, not 100 grams on up.
    Like these.
    http://www.oldwillknottscales.com/1-gram-calibration-weight.aspx
    http://www.oldwillknottscales.com/5-gram-calibration-weight.aspx
    Sinkers could be cut down in weight.
  • inspiredsports
    edited June 2009
    Thanks! The problem I'm up against is that I do not know the actual weight of the original Grace hunk of steel that goes on the anti-skate rod.
    The original weight delivers .75 grams of anti-skate bias in position #1, and then adds +.25 grams for each incremental position. However without knowing the exact weight of the original piece, it is impossible to know what force is being generated in the various positions as it is relative (and leveraged) to the starting weight.
    As best as I can determine from measuring the rod (2mm), and then comparing proportions from photos, the original weight dimensions are 6mm in diameter by 4mm in length with a 2mm bore through the center and a 2mm set screw coming in from the side.
    I have a precise 3 gram SME weight here that measures 8mm dia. X 10mm length with a 2mm bore so I'm calculating by ratio that the missing Grace part weighed .75 grams if they were constructed out of a similar metal.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited June 2009
    I've been researching this for about a month now and have determined there are very few sources out there for Grace parts and information.
    By trial and error (and matching my guess from extrapolating weight versus size prom a photo), I've determined the 707 tonearm functions best with an anti-skate weight weighing .75 grams.
    I cut various small pieces of aluminum tubing, weighed them with a stylus gauge, and then did countless listening tests until the sound quality of the right channel matched the left with the weight in an appropriate spot on the anti-skate mechanism lever. I'm having a nice little .75 gram piece of stainless steel (6mm dia. X approx. 4mm long with 2mm bore through the center and 2mm set screw) fabricated until I can find an original on the vintage market.
    My next project is refurbing a table with an Infinity Black Widow
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited September 2009
    Updating my search for a Grace 707 bias weight,
    I located the exact original part from a man I found in California who had an extra. He mailed it to me in a plain white letter sized envelope for $20.
    When it arrived the envelope had a nice hole in it. When the envelope hit the automated rollers used to process letter mail, the weight must have been ejected like a watermelon seed squeezed between your teeth.
    I then tracked down a guy in Australia who manufactures them and sells them on eBay. . .
    http://shop.ebay.com/tempo*5/m.html?_nkw=&_armrs=1&_from=&_ipg=
    It's perfect.
    The Grace 707 is one of the lowest mass, best tracking, best sounding vintage tonearms I've ever owned.
    I've also just finished up rewiring an even lower mass carbon fiber arm Infinity Black Widow.
    These arms join my SME 3009 Series III with nitrogen hardened titanium "S" armtube giving a triumvirate of 3 of the lowest mass tonearms ever produced. With fastidious setup, it is simply amazing what these arms are capable of retrieving from a spinning piece of vinyl.
    All three require high compliance cartridges with 20 x 10-6cm/Dyne or greater compliance (25 to 35 even better) and I've amassed quite a collection of high compliance cartridges to outfit the arms.
    All three are mounted on restored/tweaked Thorens TD-160 BC Mk II's.
    I can finally concentrate on listening.
    Vinyl life is sweet around here now :)
    NAD SS rigs w/mods
    GIK panels
  • paulszakal
    paulszakal Posts: 1
    edited August 2010
    Where can I purchase a new cable for my 707?
    Its the one that connects the bias weight arm with the back of the arm underneath--maybe 1&1/2" looped on both ends.
  • inspiredsports
    edited August 2010
    paulszakal wrote: »
    You might be confusing the Grace 707 with another brand tonearm. I've never seen a Grace 707 with the part you are describing
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited August 2010
    paulszakal wrote: »
    Grace parts seem nearly impossible to find.
    SME uses a similar line with their weights and I have seen some weights with line listed on eBay by a company called squareheadtubes. You might be able to modify the line to the proper length needed on the Grace.
    NAD SS rigs w/mods
    GIK panels
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited August 2010
    Here's the Vinyl Engine database page.
    Interesting to hear about such low mass from this arm. My MG1 I thin kI had estimated at about effective mass of 4g at one point but I could be wrong.
    I always use the Grados on it.
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • inspiredsports
    edited August 2010
    paulszakal, I misunderstood your original post thinking you were looking for an electrical cable.
    You are correct there is an extremely small gauge nylon or plastic line with a loop at each end that attaches between a pin on the bottom of the back end of the tonearm shaft to another pin on the hinged lever that holds the bias weight.
    When I first purchased and was restoring this tonearm about a year ago, I read every article on the Internet I could find about the Grace 707. I found virtually no parts available, just the occasional broken arm offered for parts.
    The loops on this line are engineered such that they spread open to allow you to slide them over the pins, and then pinch back closed so they don't fall off of the pins. It would be extremely difficult to fabricate a direct replacement unless you have fly fishing fly tying equipment.
    It is worth pursuing though as the 707 is a stellar performer when set up correctly.
    NAD SS rigs w/mods
    GIK panels
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2010
    The vintage arms just have that twinkle to them that the newer arms can only hope for. They came from the period when vinyl was king.
    My Micro Seiki arms are hard to find parts for also, especially the Max-282. Thankfully mine is complete at the moment and hopefully for a long time. My MA-505 and MA-701 are a little more common albeit expensive to replace.
  • pcourtney
    pcourtney Posts: 2
    edited August 2014
    the ebay id of the guy in Australia for the bias weight is ldvalve and I can highly recommend him.
    search for Grace G-707 or G-727 or G-840F tonearm Bias weight, but as of today he only has 10 left
    Brand new Bias weight make out of Brass also know as anti-skating weight for Grace G-707 or G-727 or G-840F , it also fit the Audio-craft series AC4000/3000 may be other arm too but i just don't know.
    they are custom made using Brass using 2.5mm stainless steel metric knurled screw , this weight might be suit other arm anti-skate device with the centre hole of 2mm. very high quality all hand made made and finish with accuracy is within 0.02g compare to the original bias set .
  • pcourtney
    pcourtney Posts: 2
    edited August 2014
    Grace Tonearm G-707 Anti-Skate Wire, and for models 727 and 747
    a chap in Canada, ebay ID = cr_investments
    he has the Anti Skate wire for sale $19 USD
