PSW10 in corner
Dan2036
Dan2036 Posts: 148
edited June 2009 in Speakers
I have a pretty small room and basically the only place i can put my sub is in the corner of my room and it's got a tv stand to the right of it a wall to the back and side so i assume this is whats making it so boomy, anyone know anything (cheap) that i can do to fix this ?
TV- Samsung 24" LCD T240HD
5.1 Receiver - Harman/Kardon AVR 247
Stereo Receiver - Harman/Kardon 3390
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD :D
Playstation 3
Post edited by Dan2036 on
  • skrol
    skrol Posts: 3,399
    edited June 2009
    Without hearing what you are hearing... If attenuating using the output control doesn't work, you might try shifting the crossover point. You may not have a lot of latitude blending with the TSi100's though. Another idea is to stuff a sock in it. That's right placing a sock or other material in the port may calm things down enough though it will also change the tuning of the enclosure. It won't break anything. Just don't push it all the way inside.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • DanAckerman
    DanAckerman Posts: 70
    edited June 2009
    Try moving it out a few inches from the walls if possible.
  • Dan2036
    Dan2036 Posts: 148
    edited June 2009
    should i raise or lower the crossover point ?
    Will try the sock if that doesn't work thanks
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    I would leave the cross over to what matchs your speakers. You might want to lower the gain on the sub.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
