What amps to use
roc111672
In my boat i have 4 polk db651`s on my wakeboard tower And 6 db651`s in the boat . Right now there is an amp on the 4 tower speakers and an amp on the 6 in the boat .I would like to replace the amps but am unsure which amps to use . Any help is appreciated .
Thanks Rusty
Thanks Rusty
Post edited by roc111672 on
What's your budget? Which amps do you have now? What is wrong with them?LSIm system on order =D
Currently listening to innovation...
Prior car systems:
Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500 -
The amps i am going to replace are ... SPL 480 watt and some 400 watt without a name on it . My reason for replacement is the ground wire on the battery came off and hit the positive terminal and now i am getting a horrible noise through the speakers ( a constant popping noise while the motor is running ) And also a whining noise . The noise only comes through the speakers with the SPL amp on them . So i figured i messed up that amp . I bought the boat used and this stuff was in it . I just replaced the tower and boat speakers .The install looks horrible so i figured i would replace everything and do it right . As far as budget i havent given it any thought .
Also since i have no idea what i am doing . Do i need a 4 channel amp (1 channel for each speaker ) on the wake board tower speakers (4) and a 6 channel for the 6 in boat speakers ?
