SVS pb-12 Ultra
mdk5068
mdk5068 Posts: 204
Hey guys,
So I just picked up an SVS pb-12 Ultra the other day, about a year and a half old. When I picked it up, I asked the guy to put on a demo for me, and the thing blew me away. i couldn't hear, think, or keep that dumb*** grin off my face. I took it home, plugged it in to my Yamaha rx-v659, and .... nothing. I fidgeted, upped the gain a little bit, and I hear the subwoofer, yes. What I did not hear, was the inhuman pounding that I heard in the demo. Any ideas? Is my receiver not powerful enough? It has 100w x 7channels, not quite sure why with my 5.1 setup it would not be pounding.
I need more bass in my life,
Mark
Bulls make money.
Bears make money.
Pigs get slaughtered.
You, my friend, are the bacon.
Post edited by mdk5068 on
  • polrbehr
    polrbehr Posts: 2,857
    edited June 2009
    How do you have it hooked up, first of all?
    Your amp should have nothing to do with that sub, it's got its own amp built-in (900W, IIRC?)
    Edited, the Plus2 has 900w, not sure about the Ultra, sorry.
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    The SVS pb-12 is a great sub, you must dont have it hooked up correctly.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • McLoki
    McLoki Posts: 5,231
    edited June 2009
    Are you sure you have the sub set to "on" or "Yes" in your AVR?
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    +1 to what McLoki said. Also how do you have it setup to your AVR?
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • McLoki
    McLoki Posts: 5,231
    edited June 2009
    Can't edit my old post, but I would also check to see how your other speakers are set up. To start with set them all as small (regardless of how large they may be) with an 80hz crossover. (once we start getting bass - then start adjusting from there)
    Michael
  • mdk5068
    mdk5068 Posts: 204
    edited June 2009
    wow guys thanks for all the advice! I will check my speakers, but in terms f how it is connected, I just have a bettercables subwoofer cord put into the jack on my receiver. The internal amp really encourages me, though, just so I know I have everything I need to change. I did the autocheck on my receiver, with the mic, and it detected the sub and even played tones. I heard the woofer during a movie, but it wasnt as large sounding as when i demoed it. I will check everything and get back though! Thanks for all your advice!
    Bulls make money.
    Bears make money.
