Denon 1910 (or 1909) and Monitor Series
bp_
bp_ Posts: 6
edited June 2009 in Speakers
Hello,
I am looking at the Monitor line of Polk speakers to match with the Denon 1910 (next in line after the 1909 - basically the same model). I was thinking of going with:
L/R Front: Monitor 40
Center: CS2
Rear: Monitor 10 (tho may stick with my Magnavox crappy ones for a bit)
Sub: For now a crappy powered Magnavox I have from an older HTIAB.
Thoughts about this setup? Was looking at the Polk Audio RM6750 but I imagine these Monitor's would sound much better and they wouldn't be that much more expensive then the RM6750. I just want to make sure I'm not overlooking anything as I am a newb to home theater setup. I probably do 80% TV and 20% music. Room size is pretty small. Not sure of the exact spects since we just bought the place and haven't moved in yet. Probably not looking to go to floor standing speakers so I figured the 40s would be the best I could do for my fronts. Thanks for any help!
Denon AVR-790
Samsung 40" LCD HDTV
Samsung DVD
Fronts: Monitor 50s
Center: CS1
Post edited by bp_ on
  • Systems
    Systems Posts: 14,873
    edited June 2009
    Personally, I would go with Monitor 60's or 70's for the front.
    Testing
    Testing
    Testing
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited June 2009
    I know some people who have used the 40's for front channels and have not been dissapointed. I currently use the 40's for surround speakers, which is their "intended" use, but again it is possible to use them as fronts. They obviously wouldn't be as good as the 60's or 70's, but if you don't want floorstanders then the 40's should work nicely for you. Hopefully someone who has some experience with the 40's as front channels will see this and give you some more/better advice. As far as "matching" the Monitors to your Denon, that won't be a problem. The 1910 puts out about 90W per channel @ 8 ohms and the 40's normal operating range is 20-125W, so you will be fine there. Good luck and welcome to Club Polk.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Upstatemax
    Upstatemax Posts: 2,742
    edited June 2009
    I would think that the Monitor 40's should keep you happy for a bit, and the Denon should have zero issues running them... Much better than a HTIAB
    My Denon AVR-2808Ci runs my Monitor 70's, CS2 and FXi3 surrounds without a problem.
  • Rodeo0530
    Rodeo0530 Posts: 797
    edited June 2009
    If you don't want floorstanders, then I would definitely go with the the 40's. Try to wait for a nice price on Newegg or something for them if you're trying to be cost-conscious. I think that they were something like $129/pair for a while because I was going to get them, but went bigger;) I like your idea of the CS2 because it's an awesome center channel, but beware. If you don't have a large area, this beast will present problems for you. I've measured it before, but can't remember off-hand just how big it is. Welcome to Club Polk, btw.
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
  • wutadumsn23
    edited June 2009
    Rodeo0530 wrote: »
    Excellent point Rodeo, I totally agree with this statement. The CS2 is an awesome center channel and as he stated it is pretty beefy, but you will not be dissapointed. Btw the measurements are as follows: 7-3/4" H x 21-1/4" W x 11-1/8" D :-)
    HT Rig
    Blu-Ray- 80 GB PS3
  • VSchneider
    VSchneider Posts: 443
    edited June 2009
    The M10 ( I was half expecting a link to vintage Monitor 10, and surprised why you'd want to use such monsters as surround, and why nobody else commented ) speaker is not a "Monitor", but from the R/T/M series one step below.
    The equivalent Monitor line speaker is Monitor 30.
    M10, R150 and like bookshelves is something almost all of us have hidden in closets (whether we admit it or not is another thing) for those cases "I just need a small disposable speaker that still sounds half-decent" but unless you already have them, I'd pick a matching set from the start.
  • wutadumsn23
    edited June 2009
    VSchneider wrote: »
    Good point, I didn't even pay attention to that. I just figured he had the 10's laying around, but like VS said I would pick up the Monitor 30's to have a better "blended" sound. NewEgg has them for $100 shipped.
    Link-http://www.newegg.com/Product/Product.aspx?Item=N82E16882290094
    HT Rig
    Blu-Ray- 80 GB PS3
  • bp_
    bp_ Posts: 6
    edited June 2009
    thanks everyone...this is very helpful. Sounds like I should try to convince the wife that we need floor standing speakers for the front. Also, glad I got corrected about 10 vs 30 for the surrounds.
    I did read elsewhere that the CS2 was a beast but I think I can make it fit.
    Denon AVR-790
    Samsung DVD
    Fronts: Monitor 50s
    Center: CS1
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2009
    I think you will like the combo of Monitor speakers and Denon 1910 Reciever. I had a Denon 1909 teamed up with some M70 fronts, CS-2 center, M60 surrounds, and R50 rear surrounds and it sounded fantastic! Like the others have said, I would strongly consider getting M70s or M60s as fronts (preferably the M70s, they are head and shoulders better than the 60s for music). Add a good sub or two to that setup and you will have one heckuva fine system.
  • wutadumsn23
    edited June 2009
    Dawgfish wrote: »
    +1 pretty much the same setup I have and it has not dissapointed.
    HT Rig
    Blu-Ray- 80 GB PS3
