resistor and polyswitch
ANWKLO
ANWKLO Posts: 173
edited June 2014 in Vintage Speakers
What are the purpose of these resistor and polyswitch for please?
Post edited by ANWKLO on
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    What did the come out of(speaker type/model)? It does not look like anything I've come across,,but who knows? Is that original,or aftermarket,,sorry I'm not much help,but others will chime in,I;m sure. Good luck.
    The poly, is like a fuse for tweeter protection,,but your picture/application looks different,so I'm not sure of the application in this case.
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    It is inside the crossover from the original Monitor 5A with fuse, Peerless, MW6500 and 8" passive radiator:)
  • george daniel
    edited June 2009
    It looks like someone added that,, your's are fused IIRC,,so no poly was used,,do you have a pic of the actual x-over?.I would remove them if in fact they are aftermarket.Good luck and let us know what you do/happens.
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    Nobody add that. Here is the crossover:)
  • george daniel
    edited June 2009
    is there a fuse on the binding post plate?
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    Certainly, a 1A fuse.:)
  • zingo
    zingo Posts: 11,258
    edited June 2009
    Those are extra parts that someone added along the way. I would just desolder them and check to make sure all the stock parts are working correctly. Is that only added to one speakers?
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    I am the first owner and sure that no modification of the x-over ever. I have checked one speaker only:)
  • skrol
    skrol Posts: 3,456
    edited June 2009
    ANWKLO
    In an earlier post I thought you mentioned that one of the MW6500 was replaced with a MW6502 by a local dealer. Could they have added these components too? I am wondering if they could have been added to match impedance. Do both speakers have these?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • megasat16
    megasat16 Posts: 3,521
    edited June 2009
    That seems like a poly cap in series with the resistor for high pass X-over network for the tweeter. I don't think it's a Polyswitch which is different from Poly capacitor and functions differently.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    skrol wrote: »
    ANWKLO
    I was there watching the technician to replace the MW6500 with MW6502. No parts were added. Just checked another speaker, also has resistor and polyswitch:)
  • ben62670
    ben62670 Posts: 15,969
    edited June 2009
    That is not stock. Sorry. PDF's are posted here.
    http://www.polkaudio.com/forums/showthread.php?t=38755
    The resitor would have lowered the impeadance of the speaker.
    Ben
    Ben
  • george daniel
    edited June 2009
    Again,, it does not appear to be stock,, I did not know that polk used the screw/nuts to attach the crossover to the b/p plate,,IIRC they used "standoffs". Is the OP the "original owner of these speakers"? If not,,it sure appears that someone has been in there previously.
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    ben62670 wrote: »
    Ben
    I am idiot for the schematic reading. Is the 2.7 ohms resistor used correctly:confused:
  • ben62670
    edited June 2009
    I certainly would not say your an idiot. I would do a little research on what you have there and mod it appropriately. There are plenty of folks to help you out here.
    Ben
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    What is OP stands for:confused:
  • ben62670
    edited June 2009
    original poster;)
    Ben
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    ben62670 wrote: »
    Many thanks:)
  • ben62670
    edited June 2009
    I am pretty much done for the evening, but I, and many others can help to rectify the situation in short time. Stick around:)
    Ben
    Ben
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    ben62670 wrote: »
    original poster;)
    Of course:)
  • george daniel
    edited June 2009
    I think what Ben and myself are saying,is that it appears that someone else has been inside those speakers before you,,hence the question,of are you the original owner. If not,,it might be a good idea to remove the resistor ,etc,and see how they sound. Good luck.
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    I am the original owner and bought them from HiFi shop:)
  • george daniel
    edited June 2009
    So, they were new when you purchased them? Those are 25+ year old speakers.I'm not disputing your statement,,but I have never seen a resistor and poly on that speaker,and I own a pair as well.The mystery continues.
    F1nut Posts: 51,938
    edited June 2009
    ANWKLO, as Megasat16 stated, that is NOT a polyswitch, it's a capacitor in series with a resistor.
    I don't know a whole lot about that model, but since you bought them new, they must have come from the factory that way. Looks like the factory decided a little tweak was in order. Simple as that.
  • george daniel
    edited June 2009
    I just finished a search,, and it's a capacitor(film?) and not a polyswitch.
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    Then, does it match with the schematic of Monitor 5:confused:
  • george daniel
    edited June 2009
    ANWKLO wrote: »
    not that I can tell.
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    Correct:)
  • george daniel
    edited June 2009
    Well,,then,,like Jesse said,,must have been a "tweak" that Polk used/performed,,you certainly seem to have a very unique model/version. Also,,that is a capacitor and not a polyswitch(since you have a fuse).How do they sound?
  • ANWKLO
    ANWKLO Posts: 173
    edited June 2009
    Am I lucky or not:confused: They sound airy , bright and tight:)
