Books on electronics repair
tcrossma
tcrossma Posts: 1,301
edited June 2009 in Electronics
Does anyone know of any good books or other resources to learn how to do some basic electronic repair? Things like replace the binding posts in my amplifier, learn more about how amps work, learn to replace capacitors and resistors, how to discharge a capacitor, etc. I want to start learning how to do these things and have no idea where to start.
Thanks.
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2009
    Parts Express/Amazon has many different books and learning materials. I would suggest you also study some theory too, if you're going to be playing with the stuff, be safe about it. Some of those caps carry high voltage for sure, so I suggest learning how to read schematics as well. I would suggest a class or two, but that's just me. Removing caps, etc requires the use of a solder iron and knowing how to use it. I learned how to solder real well through practicing on a blank PCB board. Go to the Rat shack buy a few resistors, boards, and other components and try that way. Search on Amazon came up with
    http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=Electronic+theory&x=0&y=0
  • tcrossma
    edited June 2009
    Thanks for the link. I did an amazon and google search before posting here, but I couldn't seems to find a definitive source for how to learn this stuff. I'm most definitely willing to learn some theory, in fact I'm itching to. And as far as practicing soldering, most willing. I've done a little here and there, but still a novice.
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2009
    tcrossma wrote: »
    You can do what I did to learn electronics and repair. Join the Navy, take their aptitude test, find out you have an talent for that type of thing, and go to their electronic schools. Maybe the books are a better way. :)
    Seriously though, this type of thing really is a hands on experience, and you need all types of (expensive) test equipment in order to troubleshoot most problems. There probably are some type of trade schools in your area that offer courses in this area.
  • tcrossma
    edited June 2009
    Yeah, joining the Navy is not an option :)
    I don't need to become a complete expert here, and I don't need to be able to diagnose and repair every problem that might spring up. Being able to replace a few things, get some basic understand about how amps and audio equipment works, and just generally learn some of the ropes is what I'm looking for. And hands-on experience is wonderful (and I'm looking forward to it), but I don't want to just dive in blind, so I need some resources.
    mhardy6647 Posts: 35,033
    edited June 2009
    You don't have to join the Navy to avail yourself of NEETS:
    http://jacquesricher.com/NEETS/
    Here is (are?) a passel of outstanding resources, courtesy of DIY-maven Pete Millett:
    http://www.pmillett.com/technical_books_online.htm
    http://www.pmillett.com/tube_data.htm
