PSW1000 vs SVS
mufsoman
mufsoman Posts: 635
edited June 2009 in Speakers
Does anyone have any experience with the Polk PSW1000 sub? This is the dual 10" sub. Is it worth the money vs a comparable SVS? Maximum room size its good for? Thanks
Parasound HCA-2003A & 2205A
Front: Rti12's
Center: Csi A6
Side surrounds: Polk Rti A1's
Atmos: Mirage Nanosats
APC H15
Power cords by Pepster, Morrow MA4 IC's, AQ Midnight, AQ Chocolate HDMI's[/SIZE]
The rest is TBD.
Post edited by mufsoman on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2009
    Whats your budget?
  • mufsoman
    mufsoman Posts: 635
    edited June 2009
    $500 - 600. I've been looking for used SVS. Just waiting for the right deal and in the Chicago area or reasonable driving distance
    Front: Rti12's
    Center: Csi A6
    APC H15
    The rest is TBD.
  • polrbehr
    polrbehr Posts: 2,837
    edited June 2009
    http://cgi.ebay.com/DSW-microPRO-2000-8-inch-1200-watt_W0QQitemZ220418040262QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item3351f061c6&_trksid=p4634.c0.m14.l1262&_trkparms=%7C301%3A0%7C293%3A1%7C294%3A30
    Something I would consider over a PSW1000, even though I've never actually heard that particular model. I have heard a MicroPro, though, and they are hard to beat, and will handle music very well in addition to HT (you don't say what you're primary use will be).
    I own an SVS, and think highly of them, but I think you'd have to wait awhile before you would find a comparable sub from them in your price range. There is one for sale in our Flea Market you may want to check out, a PB12-Plus/2, IIRC.
  • mufsoman
    mufsoman Posts: 635
    edited June 2009
    My set up is used only for HT. The room is somewhat large, 26' x 26' x 7.5', but the HT is just a portion of that. The rest is pool table area, bar, etc. It's a large area to fill and get a good chest thumbing bass. I currently have a 8" sub left over from a OmniSat system I used to have. Its way undersized for the room and to accompany the Rti8's. The SVS PB12+/2 is in Vegas, I'm in Chicago, too far for shipping. There's a PSW1000 available locally, just wondering if it's worth it to consider or keep waiting for a SVS?
    Front: Rti12's
    Center: Csi A6
    APC H15
    The rest is TBD.
  • megasat16
    megasat16 Posts: 3,521
    edited June 2009
    There are a few models SVS offer and currently, PB13 Ultra is their top of the line. I have both PB13 Ultra and PSW1000. While PB13 Ultra retails for around $1500 and PSW1000 can be found around $500 used or NEW, I think there is no comparison between these two for their output (SPL). The PSW1000 fits nicely for small HT room but the room your size requires two or more of the PSW1000. SVS PB13 Ultra hits to lower frequency (more bass down) than PSW1000 and louder but single PB13 Ultra may or may not fill your room as well.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • polrbehr
    edited June 2009
    mufsoman wrote: »
    OK, I did not realize how far away it was. Road trip? :D
    If you could arrange a demo of the 1000, I say give it a shot.
    But that's a huge room to try to fill with bass, regardless of which sub you look at (my 2 car garage is 26x26x8). It will be even more difficult if you are on a slab. An Ultra 13 may indeed be in order here. Good luck with this, report back with your solution.
    And hey, an HT room with a bar and a pool table is not the worst problem to have!
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2009
    I have a PSW1000 in an 11x12 room, and it will knock you down and kick you in the chest in the process if it is turned up. It blends in perfectly with 4 LSi15s. The cannon fire in Master And Commander makes you think you have just been hit by a cannonball.
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    $500 to $600 is a price range were you can get into a lot of good subs. I would recomend keeping an eye out for a used Sunfire True sub. Can't go wrong with 2700 watts of power that goes down to 18hz.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • gtu2004
    gtu2004 Posts: 620
    edited June 2009
    at that price range, MFW-15 probably is the best you can get. It is almost as good as the SVS Ultra 13 for much less $$$
    Onkyo 805, RtiA5s, Csi5, Rti6s
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Go for the SVS sub!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • mufsoman
    mufsoman Posts: 635
    edited June 2009
    All good advice. I think for the size of my room I'm going to pass on the PSW1000 and keep looking for the right SVS deal. I have investigated the MFW15, but I'm concerned about the reliability of the amps. There's lots of chatter about bad amps. New MFW15's are shipping the end of June with a "new" amp. These are reduced $200 for anyone interested. This is still an option, just concerned about taking a chance with an unproven fix. Thanks to all. Anyone want to sell their SVS????
    Front: Rti12's
    Center: Csi A6
    APC H15
    The rest is TBD.
