will this system work?
the von
REPOST: i posted this in the wrong thread.....now its right....
i'm extremely new. i've tried researching on the internet, got some basic knowledge... just trying to get a sub in my car with sum decent bump. my speakers are fine in my stock honda accord, but should i upgrade? these are the speakers i'm considering....
http://www.newegg.com/Product/Produc...82E16882647036
Also this amp with this sub
amp.
http://www.newegg.com/Product/Produc...82E16882863054
sub.
http://www.newegg.com/Product/Produc...82E16882863059
i know they arent name brand... but for the price.... can't beat it.... but i will also need a box for the sub....
so theres the possibility of going with the deal at crutchfield
sub.
http://www.crutchfield.com/p_236T451...04.html?tp=111
and if i buy two... i get a free box for them.
but in the near future...[for a grad present] i am getting my girl a sub and amp. would i be able to do some changes to that box to separate it into two boxes? or am i crazy? i thank you guys in advance for the help!
amp.
sub.
sub.
Post edited by the von on
I would really help if you posted links that didn't have ... in the middle of them. None of your links work.REPOST: i posted this in the wrong thread.....now its right....
amp.
sub.
sub.
but in the near future...[for a grad present] i am getting my girl a sub and amp. would i be able to do some changes to that box to separate it into two boxes? or am i crazy? i thank you guys in advance for the help!Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
well this is annoying.... i can not edit my post.... lame.... here's the links that work...
speakers....
http://www.newegg.com/Product/Product.aspx?Item=N82E16882647036
amp
http://www.newegg.com/Product/Product.aspx?Item=N82E16882863054
sub1-
http://www.newegg.com/Product/Product.aspx?Item=N82E16882863059
sub 2- where i'd buy two of em with bual box
http://www.crutchfield.com/S-oF8xuK0nFG0/p_236T4510/MTX-Thunder4500-T4510-04.html?tp=111
sorry about the messed up post.... very annoying...
also i'm just graduating and cant get a job yet... so i figure i might as well spend some time takin my car apart and tryin to wire it myself.... youtube and what not the hard stuff.. i'm fairly good with technology.... so whats the worst that i could do? -
Welcome to car audio! I just got into car audio myself, and gl with your install
You can run the clarion speakers from your hu possibly, its rated @ 35rms.
The amp is over powered in bridged for the first subs, unless you are wiring it @ 8ohms then it should do the trick. As for the second pair of sub, it will run both sub in each respected channel. However, you won't be able to push it to its full potential. -
I've seen Best Buy set a car on fire. I think that constitutes the "worst that can happen."Never kick a fresh **** on a hot day.
The head unit might be rater at 35, but when it's trying to push that much, it won't sound too clean. It might put out like 10 watts cleanly. As far as the amp, it's not really over powered for the first subs, its probably just perfect for it. But I'd recommend the MTX's anyway. If possible I'd step up to a slightly more powerful amp. Better to have more power and not use it, then not have enough and push the amp into clipping and blow your subs.1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
spwuinmk67 wrote: »The head unit might be rater at 35, but when it's trying to push that much, it won't sound too clean. It might put out like 10 watts cleanly. As far as the amp, it's not really over powered for the first subs, its probably just perfect for it. But I'd recommend the MTX's anyway. If possible I'd step up to a slightly more powerful amp. Better to have more power and not use it, then not have enough and push the amp into clipping and blow your subs.
500watt bridged for a 250 rms??? -
The Clairon and MTX gear are solid pieces. The speakers wont be great but theyll sound better than stock. The MTX sub is a very good sub.
The Valor amp and sub are flea market quality. The best policy for those would be something about a 10 foot pole.polkaudio sound quality competitor since 2005
I was under the impression he was getting two, if I misunderstood then my apologies.1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
well thanks for the tips. do u guys recommend any other set ups for a cheap price? i'm sure someone has the same budget as i do.... i'm lookin to stay under 250 with just gettin one sub, amp, maybe speakers.....
well, i'm planning on selling my rockford fosgate punch 300.2 amp and polk momo 8'sub in a week or so, once I have my sr 10' in place. If you are willing to wait that long, I will let it go for $215 shipped, if not it will be on craiglist/ebay.
