Please help ID these tube monoblocks
ViperZ
ViperZ Posts: 2,046
edited June 2009 in 2 Channel Audio
Hi all,
I am looking at this pair of monoblocks, which will need rebuilding.
The seem to be a DIY pair, and the seller bought them at some estate sale, so he does not have much info on them.
Do these look familiar? Do 4 tubes on the channel and some kind of a can transistor ring a bell?
Anything will help. Thanks!
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
Post edited by ViperZ on
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited June 2009
    Looks like the amplifier from an old TV set, retro-fitted with banana jacks and a power cord.
  • organ
    organ Posts: 4,969
    edited June 2009
    Never seen one of those before. Did you already get them? If you're looking for DIY, check out dynakitparts.com Brand new that you get to build.
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    organ wrote: »
    I am thinking about getting them. They are not far from Toronto (Dundas, ON) and the price is cheap (basically, I'd pay more for the transformers alone).
    On the other hand, I have a lead on the local Dynaco ST-70 in very good condition.
    So I am comparing my options. If these monoblocks are worth rebuilding (i.e. if they will push around 40+ Watts per channel), then I might be interested in working on them. Otherwise, I'd just get ST-70 and take my time modding that amplifier.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • organ
    organ Posts: 4,969
    edited June 2009
    That's awesome. Whichever one you go for, I think you'll have a blast. I have an ST-70 that I put some work into. They are excellent amps. Keep in mind that with the stock configuration, you could also run KT66, 5881 and 6L6GC output tubes on them.
  • organ
    organ Posts: 4,969
    edited June 2009
    Forgot to ad this on my previous post. Do you know what kind of output tubes they use? YOu mentioned that they use 4 tubes, are they two signals and two outputs? If two outputs, they're in a push pull configuration and if you know the type of tube, you can guesstimate their output power.
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    organ wrote: »
    I'll most likely get the ST-70 tomorrow, but these monoblocks definitely look like an interesting project.
    I have no idea, which tubes these amps use, but I can do some calculations and figure it out, if I'll get the amps.
    From what I can see is that in each amp there are 4 sockets for large tubes and 3 sockets for smaller tubes. Looks like there is also a can transistor on the heatsink/body.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • organ
    organ Posts: 4,969
    edited June 2009
    Hope you enjoy them as much as I do. Are you getting the new kit or a used unit? I had no idea dynakitparts.com is on Dundas.
    4 output tubes should be high wattage. Not ss type high, but tube high.
    Let us know how it goes.
