Did I just screw up my 1C's???
nspindel
nspindel Posts: 5,343
edited June 2009 in Vintage Speakers
I opened them up tonight to swap out the inductors and install the Erse's that I pulled from the 2B's I'm selling.
Just out of curiousity, I put my multimeter across the speaker posts. The right channel is measuring 4 ohms, but the left channel is reading 8.4 ohms. Not quite sure what I could have screwed up here, any ideas???
And no, I didn't check the metering before I pulled the stock inductors, so I have no idea if it was like this before....
Post edited by nspindel on
  • nspindel
    edited June 2009
    Found it, snapped one of the leads off the XO out to the inductor. Easily fixed...
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    nspindel wrote: »
    What a relief !
    Glad you found it and it is repairable.
  • nspindel
    edited June 2009
    Thanks. Btw, got the t-nuts today. Thanks again!!!
    F1nut Posts: 51,723
    edited June 2009
    That kind of stuff will give you gray hair.
  • nspindel
    edited June 2009
    4 ohms, good to go!
  • nspindel
    edited June 2009
    Already have enough:p
  • nspindel
    edited June 2009
    Never realized these speakers were 4 ohms, I always thought they were 6. The Krell I'm getting next week pushes 500w into 4 ohms. Yeah, that oughtta suffice...
  • fbm211
    fbm211 Posts: 1,488
    edited June 2009
    I thought I had 6 ohm 2bs about a year ago untill I got a MM.I was pleased to find mine are 4 ohms.Is that rare to have 4ohm 2Bs?
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • nspindel
    edited June 2009
    The 2b's I'm about to sell to Big Dawg measure 4. The 1C's are actually measuring 3.6, that's probably because the resistance of the Erse inductor is lower (the whole point of using it...)
  • Face
    Face Posts: 14,340
    edited June 2009
    The DCR across your binding posts is not the speaker's true impedance.
    A speaker that measures 3.2-3.6 is more than likely 4ohms nominal, 6-7 is closer to 8ohms, etc... The only way to know for sure is to use a tool such as Woofer Tester 2 or 3.
  • nspindel
    edited June 2009
    ah, never realized that. well, the DCR was certainly good enough to find the broken lead in the XO, that's all I really care about :D
  • jon s
    jon s Posts: 905
    edited June 2009
    Question... If I were to change an iron core inductor on a crossover with an air core inductor with the same value in millihenries but the impedance is different, will that make a big difference?
    F1nut Posts: 51,723
    edited June 2009
    Yes, I would think so.
  • Face
    Face Posts: 14,340
    edited June 2009
    Do you mean different DCR's? I would look for an air core with a DCR as close to the original as possible, otherwise you might throw the speaker's balance off.
  • nspindel
    edited June 2009
    Presumably the iron core has a lower impedance, no? I just did exactly the opposite for this reason. The lower impedance definitely gives the bass a bit of extra oomph.
  • nspindel
    edited June 2009
    Anyone remember where that thread was where we talked about this? IIRC, Matthew Polk himself chimed in. I never subscribed to it....
  • nspindel
    edited June 2009
    Ah, here it is, F1 got the quote from MP:
    http://www.polkaudio.com/forums/showthread.php?t=66983
    jon s, give that a read...
  • nspindel
    edited June 2009
    You don't see posts like #21 in that thread every day...
    As for me, I've been quite happy with the Erse inductors, but that's probably because my speakers are in a small room so I don't push them very hard. In a larger room I might see some of the saturation issues described, but at the lower levels where I listen the Erse certainly is very pleasing.
  • nspindel
    edited June 2009
    Also, with respect to the saturation concerns, I just looked up the Erse on PartsExpress. While it doesn't give explicit specs, it does say this:
    "Finally, a sonically superior magnetic core coil! The Super Q line features a specially shaped core that allows for optimal magnetic performance and increases the coil's effective permeability. The result is extremely low DC resistance, reduced distortion and very high saturation levels. The coils are encapsulated in a plastic housing, which eliminates any magneto striction distortion and makes mounting a breeze. The 500 watt power rating makes these coils perfect for high power prosound applications."
  • Systems
    Systems Posts: 14,873
    edited June 2009
    Face wrote: »
    Correct it's the just the measure of pure resistance to DC.Impedance is the measure of resistance to AC plus any inductance ,capacitance.
    jon s wrote: »
    If the DCR values are reasonably close you should be fine.The air core has the potential to improve sound quality if the iron core was prone to saturation.
    Testing
    Testing
    Testing
