Paradigm PS1000 subwoofer pick up Only
devani
PS1000 Paradigm for sale. I am only asking for $30 because the plate amplifier has few burned parts. (not working) The driver is good. Cosmetically it's around 7 or 8 with no major defects... I was going to fix the plate but wife made me to get rid of few things....
Pick up in 07601 NJ $30
http://paradigm.com/en/paradigm/subwoofer_only-specification-4-4-5-10.paradigm
Design Single driver, DCBS system, high-velocity resistive ports, built-in amplifier
Amplifier: High-Current, Discrete Output 750 watts Dynamic Peak / 250 watts RMS Sustained
Amplifier Design Features Auto-On/Off, soft clipping
Bass Driver(s) 255-mm (10 in) polypropylene cone, 38-mm (1-1/2 in) voice coil, AVS die-cast heatsink chassis
Low-Frequency Extension* 22 Hz (DIN)
Subwoofer Cut-Off Frequency Variable 50 Hz - 150 Hz
Sub. / Sat. Phase Alignment Variable 0° - 180°
Frequency Response
Line-Level Input From Sub-Out / LFE-Out of receiver / processor or other line-level source
Line-Level Input Sensitivity 200 mV Mono
Line-Level Input Impedance 50 k ohms
Speaker-Level Input From left / right speaker terminals of receiver, amplifier or main / satellite speakers
Speaker-Level Input Sensitivity 1.5 V stereo
Internal Volume 56 L / 1.98 cu ft
Height, Width, Depth
(Height includes feet) 42.5 cm x 38.7 cm x 52.0 cm
16-3/4 in x 15-1/4 in x 20-1/2 in
Weight (unpacked) 25.4 kg /56 lb each
Frequency Response
Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
Receiver: HK AVR445
Source: OPPO BDP-93
Post edited by devani on
Pics for the subwooferVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
more pictures..
there are two touch up marks on the front...Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
night bump
pending sale~~Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
what needs to be done to fix it?
you will need to take plate amp to a paradigm dealer/service center.....or you can run with a plate amp of your own....but I run it with XPA-5 after amp diedVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
Sold~~Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
Congrats on the sale.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
