Thoughts on this amp?
unrealii
I already have a set of MM6501 components which I have not yet installed in my toyota mr2.
I am considering buying this amp:
http://www.blaupunkt.com/us/7607792132_main.asp
Its probably the smallest amp which will fit under the passenger seat, thats why I am considering it.
Its rated at 250w ...would a MM840DVC wired at 2ohms be a good fit for the sub?
Also, I can run this amp in 3 channel mode. MM6501's are rated at 2.7ohms. Do you think this would be a problem as the amp is probably not 2ohm stable in bridged mode? This will all be wired to a LOC from the factory HU. My original intent when buying the mm6501 was to biamp off the factory stereo with 2 sets of crossovers. Now I'm just tempted to run it through an amp and not biamp since it probably wont make much of a different coming from the factory HU.
Amplifier
Type: Digital
Number of channels : 5 Channel
Max. Power (Watt): 840
Max. Power 5 Channel @4 Ohm (Watt): 4x110+1x400
Max. Power 4 Channel @4 Ohm (Watt): 2x110+1x250+1x400
Max. Power 3 Channel @4 Ohm (Watt): 2x250+1x400
Max. Power 5 Channel @2 Ohm (Watt): 4x130+1x500
RMS Power 5 Channel @4 Ohm (Watt): 4x55+1x200
RMS Power 4 Channel @4 Ohm (Watt): 2x55+1x125+1x200
RMS Power 3 Channel @4 Ohm (Watt): 2x125+1x200
RMS Power 5 Channel @2 Ohm (Watt): 4x65+1x250
Signal-/noise ratio at nominal power (dB): > 95
Signal-/noise ratio at 1 Watt (dB): > 80
Distortion factor at nominal power (1 kHz): < 0,05 %
Frequency response (Hz) -1dB: 10-30000
Thermal-Throttle-circuit: Yes
Attenuation factor at 4 Ohm: > 100
Stability normal mode (Ohm): 2
Stability bridge mode (Ohm): 4
Input impedance (kOhm): > 10
Input sensitvity (V): 0,3 - 8
High-pass filter crossover frequency (Hz): 10 - 250
High-pass filter edge steepness (dB/Octave): 12
Low-pass filter crossover frequency (Hz): 50 - 250
Low-pass filter edge steepness (dB/Octave): 12
Automatic starting: Highlevel-input
Slot for customer specific configuration module: Yes
Pre-equipped for Plug & Play: Yes
LED for protect-mode: Yes
Inputs
Direct Aux-In (number of): 2
Direct Aux-In (connection type): 3.5 mm phone jack
Permanent supply: Yes
Cable remote control: Yes
Ground: Yes
Max. cable diameter (mm²): 10
Ignition supply: Yes
Highlevel (number of): 4
Surface connector: Silver
Outputs
Loud speaker (number of): 5
Loud speaker (connection type): Screw
Loud speaker (max. cable diameter in mm²): 2,5
Connector material: Silver
General
Height x Width x Depth (mm): 41 x 335 x 159
Installation location: Dashboard, Leg room, Glove compartment, Boot
Accessories included in delivery
Amplifier
Type: Digital
Inputs
Ground: Yes
Outputs
General
LSIm system on order =D
Currently listening to innovation...
Prior car systems:
Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500
Prior car systems:
