Does removing the faceplate actually deter thieves?
cnjvh
For Kenwood at least you can simply order a new one from the online store. Is removing the faceplate actually a deterrent? Has anyone had a head unit stolen even though the faceplate was removed?
No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR
--Stuff--
AVR: Denon AVR-3805
STB: Xfinity X1DVR
Post edited by cnjvh on
I don't know if fact backs this up, but most thieves go for the easiest and most painless hits they can. If they see a car without a faceplate and the next one has one, which one do you think they'll hit?
Now, just to prove myself wrong - I had my car broken into once with the faceplate off (this was MANY years ago, and since then have rarely bothered to remove the faceplate or do any other preventative things other than locking my door). I'm pretty sure it was just vandalism, not theft - they tore the stereo out of the dash but left it dangling - but still obviously not a deterrent to the crime, regardless of what the crime was.If you will it, dude, it is no dream. -
I only one ugraded my car's head unit so I could have a CD player. Never had it broken into but that may be why I don't put any money into my car system. I would assume that if you had a good stereo in it you would be at a higher risk of getting your car broken into.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Well, the thing with that is most people is that they dont take the face plate with them, they put it under the seat, in a center console, or in the glove box. With that, if a thief sees you have no face plate, it probably means that its a radio worth stealing.
So to answer your question, I guess it depends on the thief.
I do always take it with me so hopefully as was stated above it just makes it more trouble than its worth to the thief.No earth robot is going to tell ME which button to press!!
--Stuff--
AVR: Denon AVR-3805
STB: Xfinity X1DVR -
Didnt deter the **** who caused $800 worth of damage to my door ($1800 total) in order to steal my headunit.
I would say no. Thieves steal anything and everything. My bro had his HU stolen out of his civic at least 5 times. With and without the faceplate detached. I'd say a bigger factor to whether or not it gets stolen is where you leave your car.
