Monitor 5 Crossover Mods
Stevenmbell
Stevenmbell Posts: 60
edited June 2009 in DIY, Mods & Tweaks
Has anyone modified there crossovers in the monitor fives? If so any advice on what caps etc I should use. Thankyou Steve
2 CHANNEL:cool:
Belkin PF31Pure power/AV Conditioner
NAD C165BEE PreAmp Great Phono Section
B&K ST1400 S2 Power Amp
Audio Quest 4 Speaker Cables
ProJect RPM 1 Carbon
Ortofon Blue Cartridge
Quadio Interconnects
Denon 2910 DVD-A/SACD Player
Pangea SE 14 & AC9 Power Cords
Vifa DIY 3 ways Sound is incredible. :biggrin:
Post edited by Stevenmbell on
    heiney9 Posts: 25,630
    edited June 2009
    Here's a link from when I did my Monitor 5B's.
    http://www.polkaudio.com/forums/showthread.php?p=613756#post613756
    I used Solens, but Dayton and Clarity caps have been used by others also.....with great results.
    The schematics are in the Vintage speaker section, but it's always a good idea to pull the terminal cup and visually look at your crossover as they can vary slightly over time. That way you know exactly what you need.
    I's also highly recommend replacing the resistors with Mills non-inductive. Resistors seem to take more of a beating and if your 5B's are 2nd hand and have been even slightly abused (high volume) the resistors take the brunt of it.
    GL
  • Stevenmbell
    edited June 2009
    Heiney9
    Thank you for the posting. The pictures are a big help. This is my first try at reconstructing a crossover. I got these speakers for $40.00 and they sound fairly good. When I saw the caps I knew They could sound a whole lot better.Worst case I am out $100.00 best case I have a new set of speakers that should sound good.I bought a set of Polk R150 about six months back.And for the money they sounded great. So I bought a pair of LSi7 as I wanted a set of Audiophile quality speakers. Then came the sub then the monitor 5's I will only buy Polk's from here on out. Unless I build them myself. For the money Polk cannot be beat at any price point. I wish I had listened to friends back in the 80's when they said to listen to Polk's. I'll let you know how they turn out. Steve:confused:
    2 CHANNEL:cool:
  • zingo
    zingo Posts: 11,258
    edited June 2009
    Good luck with the rebuild and post any questions you have; I'm sure we can help. Have you decided which parts you want to use on the rebuild?
