sealed or ported car subwoofer
easorses
easorses Posts: 1
edited June 2009 in Speakers
I just purchased a pair of db1040dvc for my car. The manual says to use a sealed box of .66 cuft volume.
There was no mention of the possibility of using a ported box. Does this speaker not work well with a ported box? If it does work, what should the volume of the ported box be?
I have been reading that putting poly fill in the box improves the speakers performance. If I include it should I decrease the size of the box?
Post edited by easorses on
  • zingo
    zingo Posts: 11,258
    edited May 2009
    I would try the car audio section; but welcome to the club.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited May 2009
    .66cu ft is for Sealed. Use 1.25cu ft for vented. These figures double with two drivers in the same enclosure.
    Do what you want... Tight bass = sealed. Lower extension = vented.
    Polyfill is good to reduce resonance from the soundwaves bouncing off the sides... and should be taken into consideration when building an enclosure (volume - used space = ideal volume)
    Welcome!
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    if everything is built to spec, i'd put a quality ported enclosure against a sealed any day. in fact, i REALLY wish i had gone ported myself.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • devani
    devani Posts: 1,497
    edited June 2009
    some drivers are not suited for ported box....I don't know anything about that driver, but I would also go with ported if possible....
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
