R sda2 model
PW47
hy ilike to have some info about this particular sda ,seems there is not enough info about this model and what can be done for upgrade . thanks pw
Post edited by PW47 on
You need to post some pics of your speakers front and back, it would be very helpful for these guys to help you out with your needs. Maybe even a pic of your crossovers.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Hy ilike to know the impedance of sda2 ? 4,6 0r 8 ohms ? Thanks pwilson iam having an litlle trouble with my hafler dh 500 ,is cutting after quarter of volume ! Any guess?
Before we can tell you anything, we need to know which version of the SDA 2's you have. There are 3 versions of them.
Do they have three mid-woofers, 2 tweeters and one passive radiator? Or do they have two mid-woofers, one tweeter and a passive?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
YES.my sda2 is the model : TWO mid-woofers, one tweeter,and .. passive radiator .
well ,thanks ! my SDA2 IS THE MODEL :two mid woofers ,one tweeter, and a passive .
From there, we can narrow it down to one of two different models. Either the 2A's or 2B's. What connector does it have for the SDA interconnect? Is it blade/blade or pin/blade?
Also, you might want to pull one of the mid-woofers. If it's an SDA2A, both MW's will be MW6510's, and the SDA IC will be a blade/blade.
The 2B's will have one MW6503 and one MW6511 in each cabinet. The 2B's had both blade/blade and pin/blade IC's, but I believe most of them were pin/blade.The nirvana inducer-
My sda 2 have pin and blade ? In the gabinet back says :sda2
Dude spell check is free. Not picking on ya. I used it all the time;) Back to the speakers. The wire that connects the two speakers together will have either a round pin and a blade or a larger blade and a smaller blade.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
he.he:)JC approves....he told me so. (F-1 nut) -
If it does have a pin/blade, like Ben described, then they're SDA2B's.
The 2B's can be modified to use the RD0-198's if you're planning on upgrading the XO's.The nirvana inducer-
