TV Tuner for Projectors?
dvran
I'm getting to ready to purchase a rpojector for home theatre use, and wanted to know if anyone has added a TV tuner separatley, or know of any projectors that have built in tuners?
Thanks!
Thanks!
~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
PS3 and Xbox
Post edited by dvran on
If you have a cable box with component or HDMI out, that pretty much all you need. If you want off-the-air (OTA) HD tuner, then Samsung DTH-B260F is probably one of the best (also has HDMI and component outputs). Hope this helps.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
We most likely will not have a cable box, since we'll be sticking with the standard HD channels provided through direct coax hookup.
I did a search on the Samsung and I haven't found anything on that tuner.~Dan
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
PS3 and Xbox -
If you have a cable box with component or HDMI out, that pretty much all you need. If you want off-the-air (OTA) HD tuner, then Samsung DTH-B260F is probably one of the best (also has HDMI and component outputs). Hope this helps.We most likely will not have a cable box, since we'll be sticking with the standard HD channels provided through direct coax hookup.
Much more leads/reviews for you right here; http://www.google.ca/search?hl=en&q=DTB-H260F+us&meta=&aq=f&oq=
CheersDARE TO SOAR:
Your attitude, almost always determine your altitude in life -
Most projectors wont have tuner built in since most people use AVR as switches. Just run your output into the receiver and you should be fine.Shoot the jumper.....................BALLIN.............!!!!!
There are only a few options left at this point, within reason.
- The samsung DTB-H260F, most likely found on ebay(wouldn't worry about buying used, since there aren't any moving parts)
- TiVo, although you would have to pay the monthly fee
- Moxi (http://moxi.com/us/buy_now.html)
- Contemporary research (http://www.crwww.com/232-ATSC.asp)
-commercial grade, and definitely pricey ($600+)
- NEC tvbox (http://www.provantage.com/nec-display-solutions-tvbox~7NECJ037.htm)
-haven't tried this one, but would be worth a try-only outputs dvi though
- Hook up a computer, and use an OTA tuner card/stick (my preference is a mac mini/eyetv combo)
- DVD recorders with ATSC tuners built in (example: http://www.amazon.com/gp/product/B0014F7Z94)
- older direct tv hd receiver - just utilizes the ota tuner section of the boxTschüss
Zach -
+1 on the samsung 260! This is the one I have selected to be used with my PJ in the HT room once completed. My research led me to believe it is the one that will perform best.
Actually, the model number is DTB-H260F (just letters swapped around)
Cheers
Aaaa! Thanks for correcting me! I should have looked at mine before posting
EDIT: just saw my own SIGNATURE on this forum - it's there too.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
whats the point of a tv tuner for a pj? wana burn up that bulb with low def tv, also hows that gona work with the audio? . does these tv tuners have audio out? . you shouldent watch tv with a brand new pj bulb because the first 200 hours are the best and the brightest . May i ask what pj your thinkin about buying because theres so many out there having thier own pro's and cons, plus i got a panny ptax200u i will be sellin soon thats a great introduction to ht
- these external boxes (Samsung tuners) have HDMI out for 720p/1080i video and 5.1 DD sound. The boxes also have optical output for sound and component output for HD video. Many OTA channels are 720p or 1080i HD.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
I have the Samsung and it works great! You can usually pick them up on Ebay for under $100.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
This is for HD TV. I want to watch the SuperBowl, etc. in HD as big as possible!____________________________________________________________
Exactly.. I use my projector a lot during football season and for all the MMA/UFC fights. I use component switched through my receiver to the projector for TV.My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics -
maybe i should pick one of these tv tuners up to sell my pj , plus i love ufc on the big screen its so awesome,
Wow!! Who is your cable company? Comcast is getting rid of everything on the direct coax except for local channels, not in HD. You will soon need a cable box just to watch Sci-Fi, ESPN, etc. on extended basic. HD is another cost.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I do not have a specific model selected yet, but most likely 720p under 1000 dollars. Right now, I use the TV for playing games, watching movies, and for TV shows. It would be a waste to spend a lot of money on a PJ and only watch movies. I'd like to be able to throw up some sports at least on a 105" PJ screen.
Thanks for the tips! Much appreciated.~Dan
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
PS3 and Xbox -
I have COX cable right now, soon Time Warner.
To get the HD feed, you have to get the HD tuner and also another package upgrade which is basically another 30 bucks/month, not worth it for the amount of TV I watch.~Dan
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
PS3 and Xbox -
Thanks, I'll definitely pick one up. This option is cheaper because I now don't have to rent the DVR box from the cable company.
The room for the PJ will not just be specifically for home theater. Its a great room so we'll probably use it a lot for parties and sports games.~Dan
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
PS3 and Xbox -
I used to own the Samsung DTB-H260F, and it seemed to have very good reception sensitivity.
My only real complaint was that channel switching was slightly slow. -
Just monitor projector bulb usage. It becomes very addicting to watch TV that big and pristine. I have a smaller 20inch LCD monitor with inputs so that my kid can play his games or watch DVD's on that without using the projector bulb up......____________________________________________________________
