Epson 1080UB lamp failure
Serendipity
Tonight I turned on the PJ and I get the blinking power light for 15-20 seconds, but no picture. The fans in the unit run however.
Does this mean the unit has a bad lamp, ballast, or something else? I believe the unit is trying to power up but there is no "high-temp" or "lamp warning" light lit.
The lamp only had 400 hours.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
My Dad just came up from downstairs and told me "there's a burning smell." Does a projector lamp usually fail like this? On AVS Forum I read that some lamps on projectors can even explode.polkaudio RT35 Bookshelves
Its an expensive light bulb, it can last 5 hrs or 5000.
engtaz
sounds like a bad bulb. Don't the Epsons come with an extra bulb?Pro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands
Bad bulb. That's how they go. One day you turn it on and........nothing.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
the epsons using that new cheap bulb that gets a raoid dimming fast, but however the ETORL bulbs supposed to last 4000 hours, i suspect the bulbs wasted because of the electronics malfunctioning , there shouldent be a burning smell when a bulb blows, also make sure you got it vented ,my pj overhated in the first 3 hours because i had it back against the wall , even though the exhaust is on the front
Premature bulb fairly is not really rare and does not mean the electronics in the projector are going bad. It's simply a bulb failure, every lamp will fail @ some point, some sooner than others. Often times a burning smell is possible depending on projector. Sony PJs have a funny smell after initial install so smells are not anything you should concern yourself with unless you continue to smell it on and throughout the life of th PJ. Replace the bulb and let us know.Shoot the jumper.....................BALLIN.............!!!!!
I've had that happen once. I turned it off and waited for a while, then tried again, it powered up. -
so what was the outcome of this? did you need a bulb??My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics
