On Monitor 40's being used as surrounds, should the sound port be top or bottom?
Nightsbane
The sound port on the back, should it be on top (closer to ceiling) or should the whole unit be flipped and it be lower down?
Thanks!
Thanks!
Post edited by Nightsbane on
Not sure of the Mon 40 design but typically the keyhole wall mounting slot is on the top and the speaker binding posts are on the bottom.
I suppose it could have an impact on the sound, so why not try both ways and see which sounds best to you if there is any difference. -
Top.____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
I have my 40's with the port on the top and the posts on the bottom. Works just fine.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
