Power Conditioners
Flash21
Flash21 Posts: 316
edited June 2009 in 2 Channel Audio
Power conditioning is an area of possible sound improvement I have ignored to a large degree, but am starting to think about it a little. I have had a Monster MP-HTS2500 power conditioner for some years. But I am reluctant to spend a lot in this economy...my job could not be called secure.
I would like to have a Power Plant Premier, but I can't (won't) afford it. No way.
Anyway, if anybody has experience with these, my specific question is: would a PS Audio Power Director 3.5 be a worthwhile step up from the Monster 2500? They look roughly similar in function and features, but the 3.5 originally sold for a lot more than the 2500. There are a couple of generally favorable reviews of the 3.5 in Positive Feedback and Stereophile. Haven't been able to find much on the Monster to compare.
See sig for system...
Steve Carlson
Von Schweikert VR-33 speakers
Bel Canto eVo2i integrated amp
Bel Canto PL-2 universal disc player
Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
VH Audio Flavor 4 power cables
Polk Monitor 10B speakers, retired but not forgotten
Post edited by Flash21 on
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited May 2009
    Not sure offhand, but I picked up a balanced Power Tech. 3 Signature and sold it when I realized that my Panamax 5510 also does balanced power which works upon the same principles as balanced audio cabling geometry. I'm downsizing and feeling like if I start with balanced power filtering the juice do I really need a boatload of expensive cables?
    I'd say try to pick up a BPT used or similar device that offers balanced but I'm not an expert on power conditioning.
    Be aware the BPT CPC units don't do balanced power, thus their affordability. I believe balanced power is also referred to as AC regeneration.
    DC
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • CoolJazz
    CoolJazz Posts: 572
    edited May 2009
    No. Actually regeneration refers to a unit that is basically a 60 hertz oscillator and power amp. It generates it's own signal and then amplifies it to the 120v level using the incoming power to power the osc and amplifier stages.
    On the other hand, balanced power is saying that one leg of the AC is at about +60 volts at the moment the other leg at -60 creating the same 120 volt difference. In normal 120vac, the hot leg is 120 volts above the neutral which is close to zero. Either way is the same thing to the units power transformer. On the balanced feed, the fields cancel in a twisted wire and radiate little energy compared to unbalanced.
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • Systems
    Systems Posts: 14,873
    edited May 2009
    CoolJazz wrote: »
    CoolJazz
    Essentially,like balanced audio signals it will have high common mode rejection thus noise common to both the +60 and -60 halves will be cancelled.
    Testing
    Testing
    Testing
  • Flash21
    Flash21 Posts: 316
    edited May 2009
    Does balanced power require special cords/connectors, like balanced interconnects do?
    Steve Carlson
  • Systems
    edited May 2009
    Flash21 wrote: »
    No special cables required,its done by the transformer.Normal 120 volt AC is fed into the transformers primary,which then outputs 2x60 volt feeds from it's secondary winding.
    Testing
    Testing
    Testing
  • doctorcilantro
    edited May 2009
    I found an article on my Panamax and guess I should have read it more carefully in the past. Interesting stuff.
    http://www.thefreelibrary.com/Panamax+5510+AC+regenerator+power+conditioner.+(Components).-a0104439789
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • Flash21
    Flash21 Posts: 316
    edited June 2009
    From what I have read, I have to believe the Power Director 3.5 is going to sound better than the Monster. Which is not terribly surprising as the 3.5 retailed for 3x the price of the Monster. The Monster is probably the weak link in my system now, having recently upgraded the ten year old CD player.
    Steve Carlson
  • Flash21
    Flash21 Posts: 316
    edited June 2009
    For those anxiously awaiting my decision :rolleyes:, I found a better deal than the PD 3.5... a PS Audio Quintet, which according to PS Audio is an improvement over the PD 3.5 with much the same general features. NIB for $300 :cool:
    I think this will serve me well for the time being, and by all accounts should improve sound quality over the old Monster.
    Steve Carlson
