Wall mounts for RM7 speakers..?!?
Gvillepope
Does anyone know what model wall mounts I need for the RM7 speakers?? I purchased some omimounts but the connection did not fit the speaker... If so where can I buy them, b/c Bestbuy is no help.. Thanks!
(I know the set came with wall mounts, but i'd really like to have mounts that I can aim..)
Post edited by Gvillepope on
I was under the impression that the RM7 and RM8 came with a wall mount bracket. Maybe someone else that has used a different bracket can offer up something different, if they can stop arguing over cables and Emo long enough:rolleyes: Polk CS may be able to help with the mounts that are supposed to come with them.
1-800-377-POLK (7655) -
they did come with with mounts, but I'd like to purchase mounts that I can angle...
http://www.monoprice.com/products/subdepartment.asp?c_id=108&cp_id=10828
they have got a very good customer service and return policy.
you can check out the same mounts in BB sell for 4 times the price. -
The OmniMount 10.0 OMT is the bracket to use with the RM7. It uses a 1/4" #20 thread for the threaded insert on the bottom. For wall mounting, you'll have to use the "L" bracket with the 10.0 so it attaches to the bottom of the speaker.-Eric
-Polk Audio
