EEEEEEEEEEEKin Out More Part2
ChevyMan4x4
ChevyMan4x4 Posts: 52
edited March 2003 in Car Audio & Electronics
Sorry I did not include the full spec of my stereo the first time this is my Club polk name. I was using MoMoMan in the other post below I will include the specs so you can give me info I need to know to get the Maxium performance outta my stereo.
Alpine Head Unit -Swing Face Style-
Kicker 652Xi 2 Channel Amp
Q Logic Bandpass Box Dual 12's
2 Polk GNX 124's
CD player has 4 volt subwoofer output
amp spec are http://www.audioonlineoutlet.com/kickamp.html
Can see info there.
Thanks For the time
Sir Daniel X. Boom - the GNX slayer
Post edited by ChevyMan4x4 on
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited February 2003
    hey bud...
    well there were a few things i was gonna say "if this.. then that... yada yada" but this post gave me the info needed to be more clear...
    the head has a 4 v sub out - so u've got about the "max" in the area of pre-amp power -- no room for improvement (nor any need) there.
    two GNX 124's --- single 4 ohm coil... that's certainly enough "sub-age" (yes i know i sound like a 1985 high schooler) to do the job.
    its the amp that seems to eb the problem
    according to the website you gave me... that amp does 65 x 2 at 4 ohms stereo... or 190 x 1 @ 4 ohms bridged.
    now if u're running stereo then u're only getting 65 watts per sub.. if you're running bridged, then two 4 ohm spekaers in parallel = 2 ohms... so u're running hte amp 1) hot and 2) only getting 190 watts (or 95 watts per speaker.. which is still low).
    you need to get a little more juice... in the amp department.
    something around 150 - 200 watts per sub (as the gnx is rated 175 per sub) would definately do the trick me thinx.
    amp suggestions on the cheap cheap...
    1) coustic 401DB - 400 x 1 at 2 ohms - $299
    2) JBL bp300.1 - 300 x 1 at 2 ohms - $239
    3) Lightning Audio B350.1 - 350 x 1 at 2 ohm - $179
    4) Mtx thunder 4250D - 300 x 1 at 2 ohms - $209
    5) Rockford Fosgate 351M - 350 x 1 at 2 ohms $249
    6) US Acoustics - USX600D - 375 x 1 at 2 ohms $169
    any of those amps should be a big improvement.... they are listed in no particular order.. my personal pics in order would be the MTX (which is on sale), then the Fosgate, then the JBL.
    They are all available at www.sounddomain.com
    The Artist formerly known as PoweredByDodge
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited March 2003
    www.carstereotime.com or www.onlinecarstereo.com should have all of those amps and most likely be cheaper
    -Cody
