What causes a loud hum from an amp? really loud
danger boy
danger boy Posts: 15,722
edited May 2009 in Electronics
Without any speaker hooked up the amp.. it hums, but not to loud.. of course hooking up the speakers magnifies that hum.. i cleaned the connectors with DeOxit and it didn't help. so something must be bad... like a cap or something.
any ideas?
PolkFest 2012, who's going>?
Post edited by danger boy on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited May 2009
    uasually caps going out, is it a Carver?
  • danger boy
    edited May 2009
    ok.. but no it's a Marantz mono block.
  • zarrdoss
    edited May 2009
    about how old is it? I have a Carver doing the same thing.
  • danger boy
    edited May 2009
    about 15 yrs old. i'm not the original owner of course. these things are pretty inexpensive if I can't find someone to fix it.
    send your Carver amp to Bob (Carver) himself. I hear he work's on gear still ;)
  • lightman1
    lightman1 Posts: 10,796
    edited May 2009
    Once more, Al....strategic placement of a ball-peen hammer.:D
    Could be a loose ground.... chassis, power supply TX.....given the age of it.
    Or you could "re-boot" it.
  • zarrdoss
    edited May 2009
    There is a repair shop around the corner from me that I dropped it off at a few weeks ago and if has has not had a chance to look at it I will send it in to Bob instead, On yours, just for someone to look at it is about $30-$40 and if its a cap anywhere from 100-150 at least thats what I got on mine and I see those mono blocks all the time for $150 or so on CL. You might try ben, Good luck!
  • NewHTguy
    NewHTguy Posts: 584
    edited May 2009
    I have a very low-level "mechanical hum" with my Parasound even when it is not connected to anything bu the ac outlet. You can't hear from a few feet away, but it is one of those things that irks me just knowing it is there. Seems to be fairly common, so much so that Parasound does not have any official definition for "defective" when it comes to mechanical hums.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • PSOVLSK
    PSOVLSK Posts: 5,384
    edited May 2009
    My xpa-5 does this. The buzz/hiss is in the amp itself, but it also comes through the speakers. As NewHTguy said, I can't hear it from a few feet away, but it still annoys me.
  • Ricardo
    Ricardo Posts: 10,636
    edited May 2009
    If coming from the amp, probably a mechanical hum from the toroidal. There are several threads on this if you search. Could be DC current in your power, loose toroidal, or just a toroidal that will hum (loose wiring maybe?).
    SOPA
  • danger boy
    edited May 2009
    turned out to be a crack in the circuit board. not sure how that happen. had the amp for two years.. no problems. then all of a sudden a crack appears in the board? Odd.
    fixed now.. $60 and she's happy again. :)
  • danger boy
    edited May 2009
    lightman1 wrote: »
    that would have been my next avenue. LOL
    a ball peen hammer could take care of a lot of my problems.. both stereo and people wise. ;):p
  • lightman1
    edited May 2009
    danger boy wrote: »
    Good stuff Buddy:D
    Glad you found the problem. Sounding better now?
    tonyb Posts: 33,072
    edited May 2009
    Maybe that amp was crying out to be replaced with the MF super chargers.Glad your up and running.
