Combining Digital Music
okiepolkie
What is the best way to "combine" 2 digital files?
I have a client, day spa owner, that wants white noise played in the background, with wind chimes as an overlay. This will be a looped mp3 file, played in the massage area of the day spa.
What programs could be used to create something like this? There is a good chance he will want to add or change compilations at different times, so having a program for this would probably be better than sending out for it every time.
Tschüss
Zach
Zach
Post edited by okiepolkie on
NOt sure what you're looking to spend. A basic stereo .wav editor like Wavelab or Soundforge can mix two channels.
Adobe Audition is a more expensive piece of software but can mix multiple channels and probably give you a more professional end result. It would also give you the flexibility in the future to do other mixes with it.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
You can download Audacity for free.
Combining 2 files in Audacity is as simple as dragging both files into the main screen and then saving as a new file. You can save as mp3 or FLAC. You will need the lame_enc.dll encoder (also a free download if you don't already have it) to be able to create a mp3.
The software has a white noise generator that you can overlay with another file. You can adjust the level of each track before you save to a new file.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
I tried this program this morning, and it did what I need it to do for now:
http://www.nch.com.au/mixpad/index.html?gclid=CJKr0pm71poCFQVuswod8CQR2g
If he wants a higher quality sounding file, then he'll just have to pay more for it
I will take a look at those suggestions, just in case I need something more.Tschüss
Zach -
+1
This is a cool program. Free and simple to use. I use Audacity for vinyl to CD transfers and get very good results.
http://audacity.sourceforge.net/download/
Forgot about audacity....
I was responding at the same time it was mentioned above.Tschüss
Zach -
Didn't know about Audacity. I'll have to download it and give it a try.____________________________________________________________
