Dolby Digital Plus vs. DTS
doggie750
2 nights ago, I was scratching my head in front of the audio set up screen on w/c one is superior than the other. My guess would be the dd+, as far as i know dd+ has more bitswise capability than the normal dts but it's not all applicable when watching dvd unlike in hd dvd/ br movies. please advice.:cool:
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
I prefer DTS myself. It has less compression and a higher bitrate, and sounds a lot more natural IMO.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »I prefer DTS myself. It has less compression, and sounds a lot more natural IMO.
Same here. Whatever the reason is has a bit more oomph (great technical word) than Dolby. The drawback is most DVDs do not offer it. I've always wondered why that is. Is there a technial reason? Is it a licensing issue? Does Dolby have a deal to keep other formats off the DVD? Is the DVD creator to cheap/lazy to include DTS?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I always prefer DTS to DD. Not sure why but DTS seems more lively to me. I had heard a while back that DTS was dead but apparently that was incorrect.
Try both on the same section of movie and see which sounds better.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
I believe a DTS soundtrack typically takes more time/money to master/encode, which is probably one of the big reasons that DD is more common.
DD soundtracks are simpler to create because they use a lot more compression, and take up less space on the disc.
Whenever I have the choice though, I always go with DTS.The nirvana inducer-
Another +1 for DTS
Am I missing something here. Dolby Digital Plus is superior to DD...and should be equal or better than DTS...No? Isn't that the reason Dolby developed that format?
According to Dolby:
# Supports data rates as high as 6 Mbps.
# Bit rate performance of at least 3 Mbps on HD DVD and up to 1.7 Mbps on Blu-ray Disc.
DTS comes in at about 1.4Mbps on a DVD.
As far as I understand, there are many variables in the DD/DTS mixes that I'm not sure what I am hearing is due to the mix or the encoding. I prefer DTS over DD and DD Plus, but the mixes on the discs may be so different that it's hard to tell why.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
dudeinaroom wrote: »Another +1 for DTS
I prefer DTS also!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
According to Dolby:
cnh
so DD+ wins right or ?
Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
DTS here also, but has anyone seen any new titles with DTS? I looked some time ago, but don't see DTS any longer as an option.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
According to Dolby:
Apples and oranges comparison; Blu-Ray specs to DVD specs. On a DVD, DTS, at least to me, sounds better. The original post is a bit confused since he too is comparing Blu-Ray to DVD, and admits DD+ isn't applicable to DVDs, while DTS is.Lumin X1 file player, Westminster Labs interconnect cable
What really wins is what YOU like.
Exactly. We can throw out all the technical jargon in the world, and even if it says DD is better than DTS, it isn't changing my mind. All I know is that 9 times out of 10 I greatly prefer a movies DTS soundtrack to the DD soundtrack.
The important factor is which one sounds better to you.
I can't really speak for Dolby TrueHD or DTS HD MA though personally. I don't have a Blu-ray player yet, so I've never really gotten to sit down and compare the two directly on my own rig.The nirvana inducer-
I agree....if we're talking about S-DVDs, yes...DTS over DD.
But on HD-DVD, Blu-ray....DD+ clocks a little higher. Bluefox is right though. We should stay on format.
So DD+ becomes somewhat irrelevant on Blu-ray because it is a lowly standard compared to Dobly Tru-HD and DTS-HD Master Audio formats.
Perhaps some clarification:
1. Dolby Digital and DTS came out with two new formats during the advent of Blu-Ray/HD DVD. These included DTS-HD, DTS-HD Master Audio / Dolby TrueHD, Dolby Digital Plus.
2. DTS-HD and Dolby Digital Plus were lossy formats used to allow consumers to hear benefits in sound even using existing wires (SPDIF). These new formats used higher bit-rates then legacy DTS and Dolby formats and were a marked improvement.
3. DTS-HD Master Audio / Dolby TrueHD are 'lossless' audio formats used to compress audio formats in a lossless way in order to preserve the original quality of multi-channel PCM. There has been considerable agreement that DTS-HD Master and Dolby TrueHD can be compared to directly to multi-PCM and hold there ground.
3. DD+ and DTS-HD were short lived as many studios opt'd to simply include the complete lossless audio tracks, many suppliers quickly dumped the DD+/DTS-HD encoders and followed suit.
4. PCM is the gold standard of audio. Many people preferred Dolby Prologic Laser-disc's with original two channel PCM soundtracks to later offerings in Dolby Digital multi channel. A direct reference would be Apocalypse Now. The laser disc is a revelation even though it's recorded in two channel and then encoded into Pro-logic 4 channel. The DVD cut was digital and multi channel but heavily compressed. Multi channel Lossless audio and PCM should over come these down falls provided studio's continue to support Blu Ray and streaming / downloading doesn't suck the life out of BD or any other physical media. -
comfortablycurt wrote: »I can't really speak for Dolby TrueHD or DTS HD MA though personally. I don't have a Blu-ray player yet, so I've never really gotten to sit down and compare the two directly on my own rig.
I'm really looking forward to getting a Blu Ray player and trying both of the new HD formats. I'm a DTS fan now but am certainly open to switching loyalties if I like what I hear better from DD than DTS.____________________________________________________________
I really can't hear the difference. If a DVD has DTS I will play that but DD sounds pretty good to me also.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I like DTS a little better, seems to me the surrounds come to life a lot more and the front opens up more as well.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Nice discussion LuSh.
This pretty much covers it.
