Bi-wiring ?
rlewis52
I have my fronts wired though the psw450 sw. So my ? is do I run the second set of wires to my front speakers from the back of the sw or from the rev.
Post edited by rlewis52 on
In order to obtain the benefits of bi-amping, you would need two separate discrete power amps. The subwoofer's amp does not qualify as it simply passes through the amplified signal from your receiver.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
I tried bi-wiring my RTi8's a while back, with my Onkyo 606.
I found there to be absolutely no improvements whatsoever. If anything, the mid-range sounded a little drier and more withdrawn, which isn't an improvement in any way.
Like Keiko said, I'd invest the money elsewhere.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »I tried bi-wiring my RTi8's a while back, with my Onkyo 606.
this says it all.. bi wiring is not worth the trouble.PolkFest 2012, who's going>?
+1 on Dangerboy and Curt's suggestion. Although I have never tried it on my setup, the overwhelming consensus on this issue seems to be that it isn't even worth the cost of the extra speaker wire. Depending on your AVR, you could invest some money into external amplification and really bring your speakers to life.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
wutadumsn23 wrote: »+1 on Dangerboy and Curt's suggestion. Although I have never tried it on my setup, the overwhelming consensus on this issue seems to be that it isn't even worth the cost of the extra speaker wire. Depending on your AVR, you could invest some money into external amplification and really bring your speakers to life.DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
I wonder where the sudden surge on Bi-Amping threads has come from as of late, there must be atleast 3 of them going right now.HT Rig
Blu-Ray- 80 GB PS3
I had one going as well but didn't get much response. I guess it's not a very popular idea. I was glad to see the others to get a better feel for whether to pre-wire for it or not.
I agree with the others that a major difference is going with a separate amp vs trying to bleed more out of your AVR.____________________________________________________________
I think it is a popular idea, just not an idea that is going to net you very noticable differences. I know there was a blurb in my 806's manual about it and how to do it, and I would imagine it is in pretty much every 7.1 AVR's manual somehwere which is where most people's curiosity gets peaked. I thought about doing it when I first unpacked my HT equipment in Sept. but soon after joining this forum was enlightened to it's actual ability to make a noticable difference.HT Rig
Blu-Ray- 80 GB PS3
I agree with the others that a major difference is going with a separate amp vs trying to bleed more out of your AVR.DARE TO SOAR:
I bought biwire cables for my mains over 2 years ago because I didn't know any better and thought it seemed cool to accessorize my sound. I think, but surely can't prove, that I noticed a difference. And it was neither good nor bad, just different. And even if that holds water, it's almost surely attributable to the increased total 11ga signal path.
Now I've moved, they're still in the closet, and I'm running plain old XP to everything. Save your money.
