400.00 for SDA 1's
xj4094dg
xj4094dg Posts: 1,158
edited May 2009 in Speakers
Is 400.00 a good price for a pair of well kept SDA1's?
"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
Post edited by xj4094dg on
  • george daniel
    george daniel Posts: 12,096
    edited May 2009
    yes ,,,,it is
    I'm assuming you mean 1C's?
  • xj4094dg
    edited May 2009
    It doesn't say. the tweets are side by side across the top. The ad just says SDA-1.
    Thanks.
  • nduitch
    nduitch Posts: 316
    edited May 2009
    If the tweets are side by side they are either 1's or 1a's, most likely. 1's are older and have the sl1000 tweeters witht he metal plate and the 1a's have the sl2000 tweeter with the black plastic plate. Or they could be 1b's.
    F1nut Posts: 50,841
    edited May 2009
    1's or 1A's. 1B tweeters are vertical.
  • nduitch
    nduitch Posts: 316
    edited May 2009
    what is the difference between the tweeter signals on the 1b and 1c?
    F1nut Posts: 50,841
    edited May 2009
    I don't understand your question.
  • xj4094dg
    edited May 2009
    Great. Would 400.00 be ok if in good condition? Or should I wait for something else?
  • xj4094dg
    edited May 2009
    Here is a pic.
  • nspindel
    nspindel Posts: 5,343
    edited May 2009
    Do the 1's with the side by side tweeters have the dimensional tweeter? If so, are those the ones he'd want? Or maybe wait for something better?
  • xj4094dg
    edited May 2009
    bump..
  • xj4094dg
    edited May 2009
    If I buy these, what are the recommended mods for these?
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    Sweet looking speakers,good price-Go for it:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited May 2009
    xj4094dg wrote: »
    DO NOT BUY THEM $400.00 is out of line. You can get SDA2a's or b's for less than that. And they will sound better and far easier to moddify also less expensive to mod.
  • NJPOLKER
    edited May 2009
    Lasareath wrote: »
    They look nice but I have to agree with NJPolker
    Don't do it, the SDA technology wasn't quite there when they built those.
    If you have cash to burn then offer him $250
    Sal
    You better agree with me or I'll have to squash you!
  • nduitch
    nduitch Posts: 316
    edited May 2009
    I think 250 is a fair price for them. Don't worry about the tweeters, I just purchased the replacement tweeters(two of them) and will only use one per cabinet. See how they sound and if you like them, that's what is most important.
  • NJPOLKER
    edited May 2009
    How long have you been looking for some SDA's?
    What size room will they go into?
    What are you going to use to run them?
    I think these are some of the things you should think about before making the purchase. The speakers in the picture are not bad but maybe you can do better, I think you can.
  • nspindel
    edited May 2009
    If the OP is in Los Angeles, i'm sure better pairs will come along soon enough. Personally I would pass on those.
    F1nut Posts: 50,841
    edited May 2009
    Pass.
  • xj4094dg
    edited May 2009
    Now this is what (I believe) this forum is all about. Thanks Gents.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2009
    xj4094dg wrote: »
    Check out the SDA CRS+'s with stands on LA Craigslist. You should be able to talk him down to $275.
  • NJPOLKER
    edited May 2009
    Are the + CRS's a single or dual tweeter? I believe the preference is the single tweeter version.
  • leroyjr1
    edited May 2009
    The CRS+ is the single tweeter version
  • NJPOLKER
    edited May 2009
    See Brett Favre go by yet?
  • nspindel
    edited May 2009
    I used to own the CRS+'s, single tweeter. Same XO as my 2B's, so TL-moddable. Those are kickin little speakers. Go for it!
  • xj4094dg
    edited May 2009
    NJPOLKER wrote: »
    I've been looking for about a month. Not much here in LA. I'm not sure what I'm going to use to run them yet. I'm just looking to get into the SDA game. Buy some, mod if necessary, build a system.
    I'm not sure if any of the gear I have now will work as I don't know that much about powering SDA's. I have LSi9's and 7's now and am curious about the SDA sound as I've never heard it.
    I have a Parasound HCA 2200ii, Halo A23 and a Nak CA-5 in the audio closet. Will these work?
  • nspindel
    edited May 2009
    Halo A23 with the CRS+'s would be really good.
    F1nut Posts: 50,841
    edited May 2009
    Upgrading the CRS+ to the 4.1TL mod will net you some pretty sweet sounding speakers.
    They won't have the presence of the larger SDA's, but will have more than what you're using now.
  • xj4094dg
    edited May 2009
    Again, Ive never heard these, are you saying that they are better than my LSi9's?
    F1nut Posts: 50,841
    edited May 2009
    To echo Sal, "Oh Yes for Sure"
  • xj4094dg
    edited May 2009
    How much and how difficult to mod these babies.
