f/x500i good surround match for the SDA-SRS 2 ?
artinaz
artinaz Posts: 185
edited May 2009 in Vintage Speakers
We are moving to a new place and depending on which room the wife gets me and teh square footage, I will either have the 11TLs or the SDA-SRS2s as mains.
I have an opportunity to pick up a pair of the f/x500i surounds- would you consider them a good match with these speakers ?
Thanks,
Azi
Post edited by artinaz on
  • NotaSuv
    NotaSuv Posts: 3,861
    edited May 2009
    artinaz wrote: »
    Thanks,
    Azi
    using them as surrounds with 2.3tl's and they sound just fine,
  • CLPolk
    CLPolk Posts: 133
    edited May 2009
    I like mine with my SRS 2's They sound Great!!
    • SDA SRS 2
    • SDA 1A
    • Monitor 11
    • Monitor 7B
    • CS350lsi
    • RM-6600
    • FX500i
  • artinaz
    artinaz Posts: 185
    edited May 2009
    Question to you guys- are any of you using a 7.1 setup ? If so do you have teh same speakers for rears and surrounds ? Whats your setup would love to know.
    Thanks, picked them up last night. Only they turned out to be the f/x500 and not the 500i. Now have to wait to put them up in the new place!
    Azi
  • shadowofnight
    shadowofnight Posts: 2,735
    edited May 2009
    Hey Azi, right now that 7th channel ( Surround Back ) isnt used very much...you can really use anything back there without much concern...now the surround channel is very much used and really important.
    Most of the 7.1 channel blu rays ( Most of them 7.1 DTS-HD Master audio ) dont use that channel anywhere near its potential, actually the best one so far was The Golden Compass blu ray....and most of the surround information still goes to the surround channel. Hopefully they come around to using that surround back channel more in the future.
    I still have both of my setups as 7 channel though ( 7.5 in the living room and 7.3 in the bedroom ) , and have tried numerous pairs of speakers in the surround back position...if your calibration is spot on and you dont set the surround back channel hot then you dont notice much change back there.
    In the living room I use custom CRS+'s as surrounds and in wall Audio Concepts as the surround backs...in the bedroom I use SDA 2b's as the surrounds and AV123 ELT525M's as the surround backs.
    I was eyeing those f/x 500's on craigslist....are those the ones you picked up ? Good score if you did....the price sure was right :D
    The first rule of Fight Club is you don't talk about Fight Club
    Toolfan66 Posts: 17,332
    edited May 2009
    Do you still use the interconnect cable on the 2B's? I have wondered if you guys that use the SDA's as surrounds still use the interconnect and if it helps any.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • shadowofnight
    edited May 2009
    Since the SDA arrangement is still the same no matter facing at or away in reference to the speakers ( Stereo inside...dimensional outside ) , I have always used the IC.
