Speaker impedance
Vette C6.r
Vette C6.r Posts: 1,560
edited May 2009 in Speakers
Hey guys. I have been hearing alot that the LSi 15's run off of 4 ohms. My Pioneer Elite VSX 92TXH has a setting for 6 or 8 ohms but not for 4.
What would be the best setting for the LSi15's.
Should I notice a big differnce with this switch or is more suttle.
Post edited by Vette C6.r on
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited May 2009
    I'll weigh in. Select the 6 amp. It is the lowest setting and ups the amps. Such settings are for current.
    Caution: For a speaker that demands 4 amps, setting the current delivery to 6 amps (verses 4) means that the speaker will demand 1.5X the rated current push. It is not known if the stated amp can handle that, as the voltage provided must be more or less the same.
    F1nut Posts: 51,713
    edited May 2009
    The problem is the LSi's dip lower than 4 ohms, a load your AVR isn't made to handle. This will result in a less than ideal performance from both your AVR and speakers. Depending on how much volume is applied this mis-match will cause the AVR to heat up and shut down.
    It would be best to replace the AVR with one that is rated to handle 4 ohm loads or add a separate multi-channel power amp, if your AVR has pre outs.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2009
    F1 must of either took his "nice" pill or made a kill last night to quench the "thirst".....its usually
    ppfffttttttttt..........I despise recievers.
    The problem is when you set the Pioneer to 6 ohm it is actually limiting current in order to keep the component from getting to hot, even at 6 it cannot keep up with the current demand the LSi15 needs as a 4ohm (nominal) speaker design.
    Sure the Pioneer will work and I bet it sounds pretty good and can play plenty loud, but its being stressed, look for a high current amplifier to add to the mix.
    RT1
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited May 2009
    I wonder how many LSI user's under power or run improper power to their speakers and blame it on the Polk speakers.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    NJPOLKER wrote: »
    Most
    Some LSI's can dip to 2ohms
    Ben
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2009
    A lot.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • NJPOLKER
    edited May 2009
    Not to de-rail this thread but do the sales people inform the customer what they are into? I do not shop in any audio stores and have not since the 70's so totally out of touch. I think you guys are going to say they just sell and could not care less what happens after the sale. If this is true even partly where does the Polk Audio sales and marketing come in? Just wondering out loud.
  • ben62670
    edited May 2009
    NJPOLKER wrote: »
    Yep. LSI's need an amp to run properly.
    Ben
    tonyb Posts: 33,069
    edited May 2009
    NJPOLKER wrote: »
    Ya hit it on the head.Not just with Polk,but many brands of speakers.Either they run not enough current to speakers and then blame the sound on the speaker maker,or they run mega watt amps into a kliptch speaker and moan about the cost,or can't hear a difference.Understanding the basics of what gear needs to function properly is too involving for some.They would much rather have a plug and play system...enter Bose,exit hi-fi.Look at how many times the question is asked here alone about powering LSI's with receivers.I guess it's a step up by them at least asking.Too bad most ask after they bought them,then cringe at the thought of having to shell out more cash for an amp.Live and learn I guess.
  • Vette C6.r
    edited May 2009
    Thanks guys. I have heard a ton of times that I need a external power amp.
    I guess I just need to bite the bullet and get one. Just thought I could attempt to "improve" the sound I have for now.
    Thanks for the help guys.
    F1 - Monaco should be a good one. Go Kimi !!!!!!!!!!!
  • Vette C6.r
    edited May 2009
    BTW - I tried it. Switched from 8 tp 6 omhs. No difference IMO. Didn't crank it but didn't feel the need.
    Activily looking for a Carver TFM.
  • devani
    devani Posts: 1,497
    edited May 2009
    be amazed what LSI series can sound like with external amps...
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • Bernal
    Bernal Posts: 991
    edited May 2009
    Vette C6.r wrote: »
    Simple, can not set the LSI to hear sing.
    Amplifier 300 watts at 4 ohms is basic.
    1) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    2) HITACHI P55T501. 55" HD1080 Plasma HDTV
    3) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    4) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    5) POLKAUDIO LSiC (Center speaker)
    6) POLKAUDIO LSi15 LEFT (Front speaker)
    7) POLKAUDIO LSi15 RIGHT (Front speaker)
    8) POLKAUDIO LSif/x LEFT (Surround speaker)
    9) POLKAUDIO LSif/x RIGHT (Surround speaker)
    10) SONY SA-WP16 ( Sub Woofer 2X200W)
  • Emmanuel
    Emmanuel Posts: 4
    edited May 2009
    I purchased the Pioneer A/V Home Theater Receiver Model VSX-1018.So I would like to get a nice 5.1 speaker system. It seems most speaker systems are rated at 8 ohm input. My home came w/two ceiling speakers.
    They are Sonance 634T. If I purchase a 5.1 speaker system rated at 8 ohm impedance to match my A/V receivers 8 ohm output what effect if any will it have on the two Sonance speakers? Any help would be much appreciated
    __________________________________________________________________
    Best Medicine for Acne Scars
    mighty milk
  • apphd
    apphd Posts: 1,514
    edited May 2009
    Emmanuel wrote: »
    mighty milk
    I thought you said in the bi-amp jumper thread you had eD A6-6T6 Towers.
    Oh I see different spam. Take a hike
    Reported
    nooshinjohn Posts: 25,897
    edited May 2009
    Vette C6.r wrote: »
    Happy to assist in that search... I will post back and pm you with what I find.;)
    edited May 2009
