need help.....battery or starter?
doggie750
doggie750 Posts: 1,160
edited August 2009 in The Clubhouse
OKIPOLKIE....kinda need help on w/c one is causing my geo to fail when turn on the ignition. I checked the alternator and it's charging (+13V), battery checked (+12V) with multimeter...w/c lead me to the starter would be a valid candidate.:confused: However there is no sign of hesitation during jumpstart so imo it's not the starter. In need of assistance here...thank you much.:):):)
PLS NOTE: the condition does come and go.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Check your grounds/connections.
    Solenoid could be bad also
    Ben
  • WilliamM2
    WilliamM2 Posts: 4,780
    edited May 2009
    Usually the battery will read about 13.6v. Alternator reading sounds low as well, but that may be due to the battery being low and sucking up current. Any autoparts store should be able to test your battery for you.
  • obieone
    obieone Posts: 5,077
    edited May 2009
    I just had the same problem with my '02 S-10. I discovered that the rear hazards were staying on after shutting down. I tried changing out the '4-w' switch under the dash, but, it turned out to be a cruise control/ blinker switch AND relay on the column.
    I had to spend $500. on diagnostics and repairs, because I CAN'T stand working on vehicles.
    Good luck.
  • doggie750
    edited May 2009
    ben62670 wrote: »
    thanks ben, i did a major tune up about 2 weeks prior to the 1st symptom. Could it be my new comers: cable, plugs, dist cap,and rotor? pls advice.:confused:
    WilliamM2 wrote: »
    thanks will, that's about right 13.6v on my multimeter and imo it's fine. no sign of weak electrical like lights, horn, dashbrd, etc...
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • thsmith
    thsmith Posts: 6,082
    edited May 2009
    ground cable from battery, check both ends
  • sucks2beme
    sucks2beme Posts: 5,602
    edited May 2009
    Have a local parts place test the battery. They can test the alternator,too.
    But you'll have to pull it from the vehicle.
    When it doesn't start, what are the symptoms?
  • TNRabbit
    TNRabbit Posts: 2,168
    edited May 2009
    thsmith wrote: »
    Also check/clean all your grounds to frame & engine.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • ShinAce
    ShinAce Posts: 1,194
    edited May 2009
    TNRabbit wrote: »
    Ditto...
    Check all connections and make sure they're clean, especially the battery posts/terminals.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2009
    I had intermittent starting problems with my Toyota pickup....sometimes I'd turn the key and nothing would happen, then I'd try again and it would start.
    It finally wouldn't start at all - tried jumping it and nothing. Battery read full charge so it wasn't the alternator or the battery. Turning the key wouldn't even give that 'click click' sound.
    It ended up being the starter...it finally gave up the ghost.
    If the battery is being charged and holds a charge and it is intermittent - could be your starter is going bad.
  • ckphoto
    ckphoto Posts: 121
    edited May 2009
    Have someone turn the key and give the starter a whack with a hammer if it is the starter it should start. It is a easy job to do yourself 30mins. to a hour tops.
    Good Luck
    Mitsubishi WD-73736
    Pioneer Elite SC-05 :D
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Monster PowerCenter HTS 3600 MKII
    Harmony One
  • sucks2beme
    edited May 2009
    It's all a WAG. This used to drive me crazy. A clamp on ampmeter,
    and a load tester fixed that. I at least now know if the alternator
    is putting out a low output, if the starter's drawing too much, or
    if the battery isn't handling the load of the starter. We can all guess
    all day long remotely. Time to pull stuff out for testing at the local
    Autozone. After that, it's time for a run to the shop. A random short will
    drive you crazy.
    It's always so much easier when the stuff just dies. Dead is easy to troubleshoot.
  • Systems
    Systems Posts: 14,873
    edited May 2009
    Just because the battery shows a good 12v and the alt is charging doean't mean you don't have a bad cell in the battery. Have the battery load tested.
    Testing
    Testing
    Testing
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    187CAM wrote: »
    i was just going to say close to the same. my yellow top optima showed good voltage but what a tester won't do is show the battery's behavior under load. my issue was my battery. another $175 :o yellow top and i'm good to go again.
    my GUESS is it's your battery.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited May 2009
    187CAM wrote: »
    I tend to agree. A bad battery will have the proper voltage, but not the storage amps. Being bad has nothing to do with measured volts at full charge, unless the battery is completely toasted (then the voltage will stay low). It will just run down real fast, like when the engine is cranking. If over 5 years old, just replace and see what happens. You are going to soon need to replace it at that age anyway, so if that is not the problem, you are not out anything.
    The above will also explain why the engine will turn over when on a charger. The engine starter is getting its required current from the charger. Batteries gradually fail, but the failure is progressive over time.
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2009
    reported. freaks.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited May 2009
    Could be the ignition switch, not uncommon.
  • doggie750
    edited August 2009
    Mechanic Oriented HELP...
    My geo prism '96 wouldn't start yesterday but was able to from a jump start, another parent from preschool helped. Was in the parking lot with 3 babies onboard....and all hell went loose. IMAGINE the pain I have to suffer after commuting for freaking hours in traffic. Since you polkies are mechanically inclined, my question to you is this....The battery is new (MAJORITY IN THE FORUM had advised me to replace it) and my guess would be a faulty starter? Would a faulty starter w/ the aid of jump start will start a car? I know it has something to do with electrical and just couldn't figure out WTF is causing it. Usually it happens after a long drive (at least 60+ miles) during the day.
    My head believed it's not the battery/ starter nor the alternator, it's a electrical module mounted somewher on the wall..Please advice.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • madmax
    madmax Posts: 12,434
    edited August 2009
    If you have a starter solenoid problem often times tapping it with a hammer helps get the last few starts out of it.
    madmax
    Vinyl, the final frontier...
  • sucks2beme
    edited August 2009
    Time for pro help. Get it in for a diagnostic check.
    Bottom line- get them to load check everything and check
    connections. No more guessing-time for checks with real test
    equipment. We can talk this one to death. Time for action.
  • Jstas
    Jstas Posts: 14,842
    edited August 2009
    doggie750 wrote: »
    When it doesn't start, does it click the solenoid or does it just do nothing?
    Actually, better yet, get a multi-meter and check the charge on the battery.
    If it does it after long drives then I'm betting you wasted money on a battery and you have a faulty voltage regulator that isn't putting out enough voltage to charge the battery properly.
    You have a Geo Prism. Also known as a Toyota Corolla. IIRC, the regulator is integrated in the alternator. I'll check my ALLDATA when I get home about that.
    Pull your alternator out and have it tested at the minimum. I'll bet it's only pumping out about 10-11 volts. That won't charge the battery anywhere near enough to support a warm start after a 60+ mile drive let alone a cold start the next morning.
    Expert Moron Extraordinaire
  • Jstas
    Jstas Posts: 14,842
    edited August 2009
    OK, your Alternator should be putting out 13.5-16 volts.
    How to test?
    You probably don't have a battery charger so do this. Test the voltage of the battery with the engine off. What does it read? If it's less than 12 volts, the battery is drained. It should honestly be closer to 13-14 volts fully charged. Next, start the car. Test the battery again. If it was low before, has the charging gone up in voltage to at least 13.5 volts? Is it stable? If the answer to either question was no, you have a bad voltage regulator.
    If you do have a battery charger, do the following:
    1. connect a voltmeter and the battery charger to the battery, preferably a fast charger.
    2. Turn the ignition switch to on but don't start the car
    3. Slowly increase the charge rate. You will know when you have reached the appropriate voltage to mimic the charging systems because the indicators on the dash will start go out as if the car was running.
    4. Look at the voltmeter, it should read between 13.5 and 16 volts and remain fairly steady.
    5. In no voltage or the voltage is at or lower than 13.5 volts, replace the voltage regulator.
    Depending on if you have the Nippondenso alternator or the Delcotron alternator, you regulator may be integrated or just bolted to the body of the alternator. If you take the alternator out and take it to an Autozone or Pep Boys, they will test it for you and they should be able to test the voltage regulator too. That way you don't waste money on a new alternator when all you needed was a regulator at 10-20% of the price of the alternator.
  • jjwm27
    jjwm27 Posts: 123
    edited August 2009
    just start the car and carefully disconect the ground lead from the battery, if the car dies its the alternator, if it continues to run the alternater is fine, i would replace the battery, hope you get it going.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2009
    jjwm27 wrote: »
    Doing so in a modern car (with ECM) this could blow the ECM / Computer. Not a good idea.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
