Ron P. Driftwood theater
dholmes
Ron P, Love the Driftwood Theater. Did you lay carpet over the concrete floor or lay down a wood floor? Also is that carpet on the walls?I am thinking about doing my garage that way,yours looks great! Does it sound good? silly qt
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
Thanks for the kind words.
I put down black carpet over the concrete garage floor with 8lb. pad, much better than the standard 6lb. Bought the carpet and padding from Lowe's. On the walls I have black rubber backed felt. Has excellent sound control, but not over kill where it deaden's the room too much. Used 3M spray glue to attach it to the drywall. The felt can be bought at Home Depot.
Yes, a silly question. It sounds excellent. Now, if I could just find the time to finish it.Does it sound good? silly qt
Peace Out~:DIf...
Ron loves a film = don't even rent.
