subwoofer power consumption
manu4panjab
hello brothers
i want to know what is the power consumption of polk psw 125 .i'm from india so we have 220-250 voltage
i ask this because i want to buy this and i have a stabilizer with 6ampier power capacity
and also do we need stabilizers for subwoofers too
polk tsi 500.polk cs 20,polk tsi 200,two hsu uls15 15 inch subs,onkyo 807,ps3(250gb),epson tw3500 1080p projector,optoma 120 inch 16:9 screen
Post edited by manu4panjab on
bro, were you able to find the power consumption of the PWS125? I am looking for it as well!
Some people own that sub so they could help you. If crutchfield.com carries this you may be able to find a picture of the back side that will show that info....my guess is that it is that it is the same as the PSW111 since it is also a 150 watt RMS sub....I can tell you that the PSW12 which was a 100 watt RMS took in 1.25 amps (120 volts) so the PSW125 is probably LESS than 2 amps!!! or 240 watts (2 X 120).
Don't know if that helps!
Ok, I checked....crutchfield....the back of the 125 reads 1.6 amps for a 120 volt current...so 192 watts from the wall in the U.S.A. I don't know if that helps you guys or not!
