Ok Ok ok (pesci) I will replace my AMP..pleez help with choice.
RandyWilliamson
RandyWilliamson Posts: 178
edited May 2009 in Electronics
I'm blowing speaker fuses here and there...using my receiver/amp Sony STR-DE345.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE345
I should be carrying 100-110w per channel with this amp driving my pair of Monitor 10's with upgraded XO's. which will be upgraded to RDO198's tweets soon.(no other speakers are connected)
I think in the past I was looking at Adcom 555 but want to get some suggestions before pulling the trigger.
I do like to run my monitors loud at times...so I need something that runs clean juice and hi powered.
Was thinking of maybe keeping the current amp as a pre-amp if possible and also because I think it's a 5.1 system which will allow me to run in "3.1" mode while driving my Monitors off a 2 channel true amp stand alone when I want to....not sure if this makes sense to anyone...just basically that I'd like to not rule out a 5.1 setup in the future but I realize that this amp may not have the guts to drive the M10's properly....so I'd like to run the M10's with it's own power under the 5.1 sheme if it's possible...and not too much headache.
Budget is a concern as I'm trying to pick a good CD unit as well.
Not sure which way to go as I'd like to keep future prospects in mind (i love SDA's) but realize my budget will probably limit going with something that will work with an SDA speaker upgrade should it happen further down the road.
Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss"
Post edited by RandyWilliamson on
  • Dawgfish
    Dawgfish Posts: 2,554
    edited May 2009
    If budget is a concern (which you say it is) I would look for a used Adcom GFA 545 or 555, or a new Emotiva XPA-2. Of course there are many other choices out there. Keep your eyes peeled on the for-sale section of this board, Audiogon, or check your local Craig's List for deals on used Adcom's, Carvers, Rotels, Parasounds, B&K, etc. You'll be surprised what good deals pop up from time to time if you just stay patient. If you find an amp your interested in, do a search here on the board for info, or post a column asking about it if you can't find any info from the search. There is a wealth of knowledge concerning amps here in CP. Oh, and one other thing, sound is personal, so try to listen to the amp before you buy it.
    Steve
  • Face
    Face Posts: 14,340
    edited May 2009
    I'm not sure if you can use that receiver as a preamp. There's a Adcom preamp on Long Island Craigslist that would work well with the 555.
    http://longisland.craigslist.org/search/ele?query=adcom&minAsk=min&maxAsk=max
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    Try Rotel.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • RandyWilliamson
    edited May 2009
    If this current amp has a plain line out..I could use it as a pre-amp then...not that it would be of much quality I imagine but it would allow me to connect various things via it to the 2 channel amp I will probably pickup. Plus it has radio. I will check it tonight.
    Any other suggestions for a good amp? should I stick to only 2 channels? that is all I need for now but u nver know.
    Benq W5000
  • RandyWilliamson
    edited May 2009
    Rotel RB-990BX 200 watts per channel ? should suffice eh? torroidal coils!!
    Benq W5000
  • thuffman03
    thuffman03 Posts: 1,325
    edited May 2009
    Rotel are good. You could also look at Carver, Sunfire, Adcom and NAD. If you want to buy new and your budget won't permit the above look at Outlaw and Emovita.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • donedroolin
    donedroolin Posts: 225
    edited May 2009
    Check out Parasound
    TV- 52 inch LCD SONY BRAVIA XBR6
    TV- 42 inch PLASMA HITACHI ULTRA VISION
    AMP- PARASOUND HALO A-51
    CONTROLLER- PARASOUND HALO C-2
    FRONT SPEAKERS- LSi15's and LSiC
    REAR SPEAKERS- LSi7's
    SUBWOOFER- VELODYNE DD15
    BLU RAY- LG SUPER BLU BH200
    BLU RAY- SONY BDPS350
    GAME SYSTEM- NINTENDO Wii
    MONSTER POWER CONDITIONER
    WIRES- AUDIO QUEST and MONSTER
  • Ethancf
    Ethancf Posts: 474
    edited May 2009
    Parasound
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • DollarDave
    DollarDave Posts: 2,575
    edited May 2009
    I am sold on NAD - 5 of them right now (one is a receiver).
  • danz1906
    edited May 2009
    ROTEL 1090.....380watts
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • RandyWilliamson
    edited May 2009
    danz1906 wrote: »
    oooooof the stuff of dreams...you have to come out the pocket for that model....i'm trying to see if I can manage a RB991
    Benq W5000
  • RandyWilliamson
    edited May 2009
    Is it ok to pick up from fleabay?
    any other possibly better places?
    warming up to adcom due to less fatigueing highs and tighter bass.
    These don't have a volume knob...guess if I cant get my current unit to run as pre-amp I will need to pick 1 up....or is there a work around? sorry for nooob dummy question.
    Benq W5000
  • Face
    Face Posts: 14,340
    edited May 2009
    No, you need a preamp.
  • Rocco1
    Rocco1 Posts: 190
    edited May 2009
    +1 for adcom
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited May 2009
    I have no recommendation for you but all I have to say is:
    THEY F&CK YOU WITH THE SONYS! (and the drive thrus!)
