I Need Some Help
Tiffdogg187
Tiffdogg187 Posts: 1
edited February 2003 in Car Audio & Electronics
WELL HERE WE GO, I DONT KNOW MUCH ABOUT CAR AUDIO SO ANY HELP WOULD BE MUCH APPRECIATED. I'VE GOT A 93 CHEVY BLAZER 4 DOOR - NOW THE SYSTEM I'M WORKING WITH IS A ALPINE CDA-7893 POLK GXR46'S IN THE FRONT POLK EX365'S IN THE BACK AND TWO MM 12'S, NONE OF IT IS INSTALLED YET THOUGH, I WAS GONNA GET THE MTX 81000D FOR MY SUBS AND THE MTX 6304 FOR MY HIGH'S ( I CAN GET A REALLY GOOD DEAL ON THEM AT WORK) BUT I HEARD THERE WAS A RECALL ON THE SUBS SHOULD I GO WITH SOMETHING ELSE, AND ARE THOSE AMPS OVER KILL? MY NEXT QUESTION IS HOW MANY CAPACITORS AM I GOING TO NEED. THANKS GUYS
Post edited by Tiffdogg187 on
  • CPHILHOWER
    CPHILHOWER Posts: 343
    Capacitors? I would reccomend using at least a 2 farad on the MTX8100D. A 1 Farad cap should be sufficient for the MTX 6304/
    Recall? Sorry. Cant help you there.
    Chris
  • Systems
    Systems Posts: 14,873
    you need a 1.0 farad capacitor for every 1000 watts of power
    i got a 1farad rockford fosgate for 100 at www.ikesound.com
    i think it ikesound....might have been www.sounddomain.com
    cheapest i could find
    as for the recall
    if they hit the grilles theyre bad
    if theyre not theyre ok
    if you want to make sure call polk
    -Cody
    Testing
    Testing
    Testing
  • CPHILHOWER
    Never hurts to have more capacitance than you need.
    Chris
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    re caps -- dont go putting a cap in front of each amp... add up your rms.. if youre running like say 65 x 4 and 1200 x 1 , you'll get like 1500 rms... 1 farad per 750 / 1000 is a good shot... so 2 caps total will do the job... scour ebay for them ... search lightning audio or Mobile Authority and you'll find 1 farad caps as low as 40 bucks new in package -- some dont have labels... dont worry about it... a cap is a cap.
    re amp -- the 81000D is great for 2 momo's... so is an RF bd1000.1 or other similar 1100 - 1200 watt 2 ohm stable mono amp.
    re 6304 -- dude... don't buy that amp. it's doo doo. know how most mtx amps come out of the box iwth a birth sheet that shows that their 12 volt power is actually close to the 14.4 volt power? well the 6304 comes outa the box at like 50 x 4 or 60 x 4... not quite the 90 x 4 u'd be hoping for. to boot... it heats up like a mother f*****... i've never owned an amp that got so hot, so fast... and that was in 4 channel stereo -- i' d hate to see what it would do bridged... in addition, the thd rating on the 6304 is 0.3% ... that's high... u want 0.1% or less (pref 0.05 but .1 will do). Mtx does make a good amp for highs - dont get me wrong.. but its not hte 6304... the old Thunder 204 was rated 25 x 4 but came out of the box at like 50 - 55 x 4 with noticeably less distortion than the 6304... ideally if u can get ahold of a 204... do so.. if not.. a 4244 will give a much more stable, reliable, "not worried its gonna fry" performance. Two 4202's would do the same job too.
    The Artist formerly known as PoweredByDodge
  • CPHILHOWER
    PBD, I have a 2 Farad cap on my BD500. Used to be a Punch 800.2. Also, I have a 1 Farad cap on my Punch 600.4. Are you saying its not good to Cap each amp?
    Chris
  • PoweredByDodge
    no no, dont get mer wrong... its not bad at all.... its just that it's (to me) wasted energy (like human effort energy not power supply energy)... putting a cap on each amp's pwoer lead is the same as having a bank of say 2 or 3 or whatever caps.. and then running your short power line to each amp off of them (liek a distro block)... cuz in fact your BD500 mighta been suckin power off the other amp's cap as well as its own two -- or visa versa... power is power, wherever it comes from :)
