sda grill question
SpeedyFE
SpeedyFE Posts: 143
edited May 2009 in Vintage Speakers
Hey guys, just a question, on my SDAs, the cloth is loose around some edges. Does anyone know what they used, or what I should use to attach it back in place?
Thanks!
Post edited by SpeedyFE on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2009
    They use staples so I'd say just pull it and add some staples to the back.
    Are you talking about the side cloth or front grill cloth?
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    hi, i dont see any staples..
    Sorry, I mean the front grill cloth.
    F1nut Posts: 51,997
    edited May 2009
    They did not use staples on the grills or the sides, they used some type of glue. Aleene's Tacky Glue will do the trick.
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
  • leroyjr1
    edited May 2009
    I have staples on my SDA grills. Someone must have changed the cloth. Just because it doesn't have staples on yours does mean you can't add any. It'll be alot easier to add staples to fix the pull side vs messing around with glue. Both will work.
  • thsmith
    thsmith Posts: 6,082
    edited May 2009
    The side panals do not have staples.
    F1Nut I have booked make the glue you mentioned. That is one of the projects I need to do to the 1Cs, they are perfect otherwise but it drives me nuts that the fablic and backing is coming loose.
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    If I remember, you can get that glue at the local craft store. The cloth on my SRSs is coming off in places, I will use that glue and let you guys know how it goes.
