surge suppressers- line cond.
dholmes
What type of surge supp, spike, or line conditioners do most of you use? Some of them can run hundreds of $ and arent they all rated at 15amps 1875 watts, that means with some of us running mulit amps ect, we would have to have several of these. Thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
The ones made by Monster seems to be the most popular. I think their cheapest one is $699 retail. I just use a $15 surge protector.
Maurice -
Monster HTS-2500, retail $199.00. I run 5 amps, receiver, TV, DVD player off it.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
$199 WOW! I'll have to check that out. I thought the 5100 was their entry model.
Did you see/hear a difference when you hooked up all your gear to it?
Maurice -
Can't say I really did. Partly due to the fact I'm running off a direct 20 amp line from the main breaker panel of the house, the power is cleaner than if I ran off an existing outlet inside the house.
That $199 is local B&M pricing, I'm sure you can land it for less on line.
Peace Out~:DIf...
5100 entry level??? I should say not...
Well to "some people" 5100 is below entry level for a "real" HT systemMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I have to do this.
I've got a Panamax 5100. Panamax offers a lifetime connected equipment guarantee. That's all I'll say. heheh
Got it for $250. www.panamax.com
