Determining SDA-SRS, 1.2, or 1.2tl???
I am a bit embarrassed to admit, but I simply don't know which version of the big speakers I have. The serial numbers are:
Left Channel SDA-SRS 2719
Right Channel SDA-SRS 1684
Can someone kindly inform me which version I own?
Thanks in Advance,
Gary
Thanks in Advance,
Gary
Post edited by Safetyguy on
If they do not say "1.2, or 1.2 TL" after the SDA-SRS or have the chrome looking Tri-laminate dome SL-3000 tweeters(on the TL version only), you probably have the original version.
Based on the serial numbers you porvided, they sound like the original line.
Hope this helps.
Joe -
Axeman,
Thanks for the quick response. I appreciate it.
Gary -
Not a problem and welcome to the forum.
Rock on!
Peace.
Joe -
Safetyguy,
Welcome as well from a fellow SDA-SRS owner. Whacha got driving them?More later,
Tour...
Vox Copuli
After lengthy deliberation and massive indecision, I've decided to say farewell to my good friends. The big guys are currently listed on Ebay. But to answer your question, I was using a Yamaha MX-1000 power amp and they seemed content with that.
Best Regards,
Gary
