Polk DVD Theatre 360 power
vidoprof
vidoprof Posts: 6
edited May 2009 in Speakers
There are no specs on this system. I am trying to find out if the Soundbar 50 powered pretty well (70W per channel with a good AVR would be louder / better) than the DVD 360.
Any ideas??
What if I powered the SB50 with 100W per channel?
Ryan
Post edited by vidoprof on
  • bknauss
    bknauss Posts: 1,441
    edited May 2009
    Ryan - Polk will never release those specs since its a closed system and can't be paired up with anything else.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • vidoprof
    vidoprof Posts: 6
    edited May 2009
    Thanks for the reply.. Just thought I would try and get an idea to figure out how much louder something else would be.
    I am looking at a bunch of different soundbars and this one is just lacking in power IMO.
    Thank you though for the reply
    Ryan
  • svtjoe
    svtjoe Posts: 55
    edited May 2009
    Go with the 50" SB and your AVR. It will be louder than the SB360.
    The SB360 sounds good, but it doesnt go very loud. I bet its only pushing 40-50 watts per channel.
    The SB360 is a great all in one, but all in one's have their drawbacks.
    Good luck,
    Joe
