HDMI Pass-thru question....
Glen_T
I'm sorry if this has been asked and answered - I couldn't find an answer in searching.
When you hook up a DVD player using HDMI to an A/V receiver (such as the Onkyo 507 or 607) and then to the TV, does the receiver have to be turned on for the signal to make it through to the TV?
The reason I ask: Once I get my HT system set up, I want the kids to be able to play DVDs without using the receiver. I know I can make additional hookups with component video/audio cables, but it would be cleaner to just have the HDMI cable as the sole connection. Will the signal pass-through with the receiver off?
Thanks!
Thanks!
Post edited by Glen_T on
receiver must be on for the picture to pass through.Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
Rocco is right, receiver is in control of the signal so if it is off the TV will receive no input and display nothing.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
not to many ways around it. Depending on the dvd player you may not even be able to run to separate cables.Man Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
Thanks for the info....I suspected that was the case.....
Newer Yamaha, Denon, and Onkyo recievers will pass the HDMI signal to the TV when the reciever is in standby (not off). You have to choose the input you want before putting the reciever into standby.
I know the Yamaha 665 and above, and Onkyo 607 and above will do it, not sure on which Denon models. -
What about some form of powered HDMI splitter (I've heard the non-powered ones are iffy) from the DVD player to TV & the receiver. Would need a spare TV input which might mean a remote control nightmare, etc. Might be more trouble than it's worth.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Some good ideas...thanks.
My Sony has plenty of inputs, so I'm thinking I may try using the HDMI when I want to use the receiver, and when the kids just want to play one of their movies, have them use a component input and (in a sense) bi-wire the DVD player...
I'll probably wait until I actually get the receiver and then play around with it.
Thanks for the input.... -
You maybe able to use the component signal from the source directly to tv, when you wish to bypass the receiver.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
how many hdmi inputs ur tv have? if there are more than 2, u can hook up direct from tv to dvd and switch tv to dvd signal wout using receiverI am 100% BORN DEAF and No I am not kidding!
Why am I here? My wife's hearing!
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
