Corroded Speaker Wire
Freak When C
Freak When C Posts: 231
If speaker wire has got wet and the ends are corroded, can you just cut it back a foot or two, then strip the ends to reuse or re-terminate? Or could corroded ends from moisture have caused damage to the whole length of the speaker cable?
Post edited by Freak When C on
  • NotaSuv
    NotaSuv Posts: 3,871
    edited May 2009
    Had the exact same problem with a pair of Mirage M-1's...all the wire right before the connects was green....ended up rewiring all wires from the crossover to the drivers.....a P.I.T.A but there was a improvement in sound when complete...mostly heard this in the bass and mids.....was told that you can also just cut off the ends in question as long as you can cut off enough to get rid of all the corrosion.....
  • Freak When C
    edited May 2009
    So then it could be minor and an easy fix, or it could be major and affect the entire length of the wire. Interesting. I came across THIS and thought I'd ask. Looks like a decent deal but not if it's possibly corroded all the way through. Description doesn't say though. :confused:
  • zingo
    zingo Posts: 11,258
    edited May 2009
    The auction ended, but it seems like you could just cut them back in that case and reterminate. I'd probably tin the ends this time just to keep it from happening again.
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited May 2009
    The wires corroded because either moisture got introduced or a dielectric reaction occured within the wire. Very cheap insulation will allow corrosion to occur by allowing moisture in the air to pass through. I saw an article where very cheap wire was used and self corroded. In any event, the wire should be considered as junk.
    Now, if the end got corroded (not sure how in a home environment, unless there was a flood), simply snip off a couple of inches and you are good to go! My bet, though, is that the wire is junk. I have good quality 20 year old vinyl covered speaker wire that looks brand new before the exposed end that has been skinned and exposed to air.
  • Freak When C
    edited May 2009
    Yeah it's a gamble that I wasn't willing to take. Could be an easy fix but it would be just my luck to find it's corroded to the point it's junk. The seller could have trimmed it back himself and sold it as slightly shorter in good condition. Wonder why he didn't? :rolleyes:
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2009
    as Keiko said in another post, treat your wire ends, connectors, etc.. with de-oxit spray, its a great idea!
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    try this! Monster XLN 16-guage twisted pair wire with custom-terminated ends using Monster connectors soldered on. For my mains in my bedroom (currently db690's haha). actual mains to come soon. hope you can see the picture...
    http://www.facebook.com/photo.php?pid=2511187&l=16bf0353da&id=634711041
    In-Car:
    Head Unit: Sony MEX-1GP
    Door speakers: Infinity Kappa 680.9cs
    Rear speakers: Polk db690
    Subwoofers: Memphis Audio 15-M3124
    Amps: Pioneer GM5300T, Kenwood KAC 6020, Memphis Audio MCD1.1100
    In-Home:
    Harmon/Kardon AVR 230
    Harmon/Kardon DVD 101
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2009
    Keiko wrote: »
    I would've passed on those auction cables and I'd definitely not use any MC in my rig.
    Scotch bright cleans them up but I cannot guarantee what these will sound like on a high resolution sound system.
    Sold as is.
    No returns accepted.
    For the asking price, the return policy, it isn't worth the risk. I too would pass, you'd be better of keeping an eye open on good deal on use cables from fellow Polkie instead and knowing you are buying some that is worthwhile the investment.
    Cheers :)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    Keiko wrote: »
    auction cables? never heard that one... :confused:
    anyway, considering i got the stuff for $6 per 20ft spool and got the connectors at half off they seem to be a pretty good deal to me. i love those flexible wire end connectors, they're so much better than beating up the copper with the screw posts/spring terminals.
    and for the record, all these babies get used for is connecting my domesticated(in-home in boxes) db690's to my receiver for listening to terribly raspy music from my laptop...i wish there was a way to reduce the hissing caused by using that audio input from the 3.5mm on my laptop :(
    In-Car:
    In-Home:
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    ohhh that auction okay....a better cound card? for a laptop? sounds tricky...but thanks for the help! :)
    In-Car:
    In-Home:
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
