Replacement screws
Bigbang
I've been looking online at some fastener distributers and can't seem to find replacement screws for the drivers and tweeters.
Does anyone have a suggestion as to where I can find the 9/64 black hex head screw that holds down the drivers? Also the T-10 Torx screws that hold the tweeters. It would be nice to replace these as mine have oxidized over the years.
Thanks in advance,
David
Thanks in advance,
David
I like to listen, tinker, listen and repeat.
Post edited by Bigbang on
Really... Nothing?
DavidI like to listen, tinker, listen and repeat. -
I would be really interested in finding out too!!!
Off the top of my head, I think we should check out mcmastercarr.com they seem to have EVERYTHING...I will look into it...
check it out...
http://www.mcmaster.com/#torx-screws/=1x6xya -
You can simply spray paint the originals. Krylon makes a nice flat and semi-flat black.Political Correctness'.........defined
President of Club Polk -
Sorry I thought you were talking about X wife replacements.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Speedy,
Thanks for the direction. I just spoke with mcmasters and they are looking for exactly what I need. It may vary from others but I will let you know what I find once I order them. I'm looking for the following. 9/64 black-oxide hex head 5/8" long machine screw. T-10 black-oxide torx head 1/4" and 1/2" long machine screw.
cool, please let me know what you find...i would appreciate it!:D
