Carver help
2-tall
2-tall Posts: 98
edited May 2009 in Vintage Speakers
I have a chance to pick up a pair of Carver ALS111+ for $200.00 .I am going to listen to them shortly.How do they compare to my 3.1TL's.What about positioning.If they sound good I will power them with my two tfm 24's
Post edited by 2-tall on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2009
    I had a couple of hours with them at fredv's house. Comparing them to 1Cs...the soundstage wasn't as wide, but wide, very tall and feature high definition imaging (moreso than SDAs) though they didn't sound forward to me at all nor bright. The bass was more impressive. Fred's front end is considerably better than mine, but I'd consider them if not a notch up certainly worth a $200 experiment (unless they are really beat up). That's more than a steal.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • engtaz
    engtaz Posts: 7,669
    edited May 2009
    Two different animals. For 200 buy them now. I would love to have a pair. Where are you located?
    engtaz
  • engtaz
    engtaz Posts: 7,669
    edited May 2009
    TFM-24 ?? what are the specs? The TFM 22 & 25 are 225 wpc.
    engtaz
  • 2-tall
    2-tall Posts: 98
    edited May 2009
    They are the same as the 25's no meter.
  • 2-tall
    2-tall Posts: 98
    edited May 2009
    treitz3 Posts: 20,019
    edited May 2009
    2-tall, for $200.00 it is a no-brainer to get your listen on. Lower priced ones go for usually around 6 or so and I've seen mint ones go for close to or over 1K. Just make sure the ribbon works by specifically playing a piano passage at reasonably louder volumes. If the sound presents any abnormal "things" when you put your ear up to the ribbons, then pass as it is the ribbons that are the diamond [expensive ones too] in those speakers.
    As to how they stack up to the SDA's? Apples and oranges. Different flavors man.
  • 2-tall
    2-tall Posts: 98
    edited May 2009
    I brought them home and put on music with piano passages and they were fine but on some other passages I could here a buzz as if something was loose at the top 6- 12 " with my ear about 6" away.Is there a possibility of something not tight?
    edited May 2009
    Yes. I have to go back to work right now so I can not help at the moment. In the meantime, I see that you have made your way over to the Carver forum. James, the site's owner is the official Carver ribbon repair go-to guy and he can lead you in the right direction. If he doesn't get back to you by the time I get back, I'll give you step by step instructions on how to repair them..........or, if you are in a hurry, look in the Carver speaker section and look for ribbon repairs. The information you need is in there somewhere.
    Oh, it may just be an easy and free repair. No promises but from your description, you are looking good. Congrat's on your new purchase.
    edited May 2009
    Nevermind [I'm an expert on procrastination], here you go. http://www.carveraudio.com/phpBB3/viewtopic.php?f=15&t=6020
    This is James' father Dave, the original ribbonmeister.
  • 2-tall
    2-tall Posts: 98
    edited May 2009
    I'll have to buy you a beer some time.At first I went too tight and the buzzing was much worse .It ended up that I loosened the screws and most of the buzz went away.I'll give them more time before trying anything else.These were unused in a basement for ten years.The longer they play the better the sound
  • 2-tall
    2-tall Posts: 98
    edited May 2009
    Well after 4 hours the buzz is back and I can't adjust it out.It is like a very faint scraping sound.Any ideas.
    edited May 2009
    Can you locate where in the speaker it is coming from exactly?......and I do mean exactly. Put your ear up to the speaker in question and see if you can tell us if the sound is coming from the woofer, the back of the cabinet or the bottom of the ribbon. If it is not any of these, let us know where in the ribbon the issues occur, please.
    Oh, and what kind of frequency does it occur at [if you happen to know]?
    edited May 2009
    One other thing since you had mentioned a "scraping sound". Turn off all power to the rig and see if the speaker in question has this symptom. Take your hand and slowly depress the woofer in as far as it will go without using too much force. Does it come back to its normal position without any resistance whatsoever or does it seem like there is an obstruction? Try this maybe 5 or 6 times.
    F1nut Posts: 51,817
    edited May 2009
    The ribbons are very sensitive to climate conditions. Sitting in a basement for 10 years didn't do them any favors. Anyway, humidity plays havoc, so what's your environment like? You can try using a hair dryer on the areas that buzz to "dry" them out if the problem is related to humidity.
  • 2-tall
    2-tall Posts: 98
    edited May 2009
    I received help from over at Carver and may have the buzzing under control.Time will tell. These take a lot of time to position .Come to think of it so have my 3.1tl's.So far the separation of instruments is better.
