What Should Be My First Tube Amp?
Hillbilly61
Hillbilly61 Posts: 702
edited May 2009 in Wanted (WTB) Classifieds
I'm looking to take the plunge, used. Plenty modifiable with different tube swap out capabilities, etc.
Post edited by Hillbilly61 on
  • mmadden28
    mmadden28 Posts: 4,283
    edited May 2009
    Budget?
    What kind of Preamp? Or do you need one of those too?
    I've only heard good things about the Manley Stingray integrated.
    ____________________
    Pool: Atrium 60's/45's
  • Systems
    Systems Posts: 14,873
    edited May 2009
    Maybe try a Jolida or Antique Sound Labs for a low budget way to start. If you want to try tube rolling with a wide variety go for a Prima Luna. Prima lets you roll EL34's, KT88's, 6550's, 6L6's and so on. Pretty much if it fits the socket you can use it. It has adaptive auto-bias so its plug and play. Or roll and play.
    Testing
    Testing
    Testing
  • Hillbilly61
    edited May 2009
    I definitely want to tube roll. Budget wise, I'm looking for well under a grand in used condition. Final price depends upon how I get worked up concerning features, flexibility, etc. :D I intend to preamp off of existing SS integrated amp preamp outputs ... one step at a time sort of thing.
    Plus, I am formulating a theory that keeping things digitial 'till amplification may make the best of both worlds.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2009
    Lasareath wrote: »
    I have a couple of these, they work very well and they are really cheap!]
    surely you jest!?
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    http://www.beachaudio.com/AMC/Cvt-2030-p-55291.html
    go for the socket upgrade if you want to roll EL34s.
    4-8 ohm and kick some serious Polk A..
    First tuber? Can't beat them for the buck. Hybrid matches well to most preamps also.
    Great sounding amps.
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited May 2009
    I started with a Sherwood S3000 I think. then I picked up some Quicksilver Mini-Mites. Then I went with Consonance Cyber 211s.
    I do have a killer amp I don't have room for which uses one of my favorite tubes, the 5687 on the input stage. It is a push pull 6BQ5 amp, solid state rectified. If your coming from solid state, this amp would be a nice crossover point. Best part is it's not pricey and it was designed by Gary Dodd of Dodd Audio. PM if your interested. Also check out th ASL Typhoon....run some KT90s in triode on that thing but it also solid state rectified (which ain't a bad thing just not all tube - my Cyber 211 SET are solid state rectified and sound HEAVENLY).
    DC
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • shack
    shack Posts: 11,154
    edited May 2009
    I think many here would tell you just the opposite. A tube pre with a good SS amp has alway been a good combination. You will get more bang for your buck and a greater impact with a tube front end and even a tube CDP than you will with a tube amp as the first component. In fact that combo may be the LEAST effective way to get into tubes. This is JMO and others may want to chime in to agree or disagree.
  • doctorcilantro
    edited May 2009
    shack wrote: »
    True, but now with many DACs like the Lavry, Benchmark, and Weiss capable of driving amps directly I have found this path the most interesting. You could get a Scott Nixon or Wavelength tubed DAC though.
    How efficient are you speakers HillBilly?
    DC
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • nspindel
    nspindel Posts: 5,343
    edited May 2009
    That's my gig - tube pre and ss amp.
  • lightman1
    lightman1 Posts: 10,794
    edited May 2009
    Just finished rewiring my little HCT and running it to a Carver m200t, kickin' on a pair of
    1Cs. Pretty damn impressive!
    Next up, tube rolling.
    Less than $200 for a pre and SS amp.
    Ya Hick!:D
  • Ern Dog
    Ern Dog Posts: 2,237
    edited May 2009
    I started into tubes with a $300 entry level tube preamp and ran it with a SS amp. I liked the combo so much that I upgraded to an expensive tube preamp and whoa! That was a huge improvement. Then added a tube cdp, then recently added a tube amp. The result is that my rig has never sounded so life-like and emotionally engaging. Non-fatiguing no matter what the volume and the mids are lush.
    My Rogue Audio Stereo 90 is my first tube amp and it out performs all of the previous ss amps I've had in the past (Onkyo, HK, B&K). Used it sells for around $1200-$1300.
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    My first tube pre was and Audio Experience Symphonies ver1. Great little pre and enjoyed very much. Gave my old SDA's a nice warm sound. Sold it here and last i heard Russman ended up with it. Never did find those screws.
    http://www.ys-audio.com/ys-audio_eng.htm
    Sells BIN on ebay from what i remember.
    Edit. Just read Amp not Pre Amp. But if you get into tubes your prob gonna want to go all around....
    Life without music would
  • Systems
    edited May 2009
    Conrad Johnson PV series as a pre into your choice of SS amp if you want to go in that direction.
    Testing
    Testing
    Testing
