7868 tube for Sherwood 5000 II amp
HB27
HB27 Posts: 1,518
edited May 2009 in Wanted (WTB) Classifieds
I am in need of one 7868 tube for my Sherwood amp. I don't know of any interchangeable tube.
I broke one and just need one.
Harry
Post edited by HB27 on
  • Systems
    Systems Posts: 14,873
    edited May 2009
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    Thank you. I know they're available but would much rather deal with CP members. "Keepin' in the family" thing.
    Harry
    mhardy6647 Posts: 35,047
    edited May 2009
    Depending on the bias scheme in a S-5000II, you may need to replace a pair or all 4 of those or risk red-plating or even worse forms of amplifier immolation -- or find a replacement that matches the aged tubes in there already (not something easy to do).
    I have an S-5500II downstairs (7591 outputs) but I am not sure how these amps are biased (I am guessing cathode bias, but it is just a guess).
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    It's not as critical as you think. Tubes don't always age evenly even in quads and a good used tube "close enough" will do just fine.
    Thank you for the info. Still looking for a decent tube.
    Harry
  • Systems
    edited May 2009
    Cathode bias & I was refering to buying a quad of tubes. Best to do this and keep safe and sound better.
    Testing
    Testing
    Testing
    edited May 2009
    Yeah but if it's cathode bias and all four tubes are tied to one cathode resistor/bypass cap... if there's one that draws more current than the other three... it may not be pretty.
    Don't say we didn't warn ye.
    I'd recommend buying a quad of EH 7868s matched by a reputable dealer.
    I will check downstairs and see if I have a loose one floating about.
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    Thanks all. Got one used and amp is sounding and working A-1. I appreciate all concerns and thanks for help and suggestions.
    Harry
    (btw, I'm an electronics tech (have been since '67) so all is well in electrocution land)
